Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Zenith 44" LCD TV
I've got a Zenith 44" LCD TV which was workin fine, had some light yellow haze in the center of the picture other then that color was good and working. Then one day all of a sudden the picture went off sound but no picture. Message on the screen reads searching for signal signal. At first I thought it was my box but turns out its fine. I can change the channel and the sound will change according to what it showing but like I said no picture????
  • 2 more comments
  • tc5591 Aug 04, 2008
    My blub light was on so I replaced the bulb and still have a blue and yellow haze. Any solutions?
  • mgreene820 Aug 17, 2008
    I have yellow hue band across the top and bottom of the screen. The picture has been darker than usual. I've adjusted the color and settings, but have the same display. The sound quality and everything else is ok.
  • jd20lawl Aug 25, 2008
    I actually have this television because my friend gave it to me. He had bought it about 3 years ago. He said the problem was that one day only static appeared on the screen. The sound worked fine. He had it checked out and was told that the problem was with the light machine, which as it turns out zenith no longer makes. This however seems kind of weird to me considering the menu still appears when you press it. Does anyone know what else this could be?
  • Anonymous Mar 21, 2014
    installation guide does not find channels during search mode. message is no signal.
    Problem Solver:
  • 9 Answers
The yellow spot is due to the BLUE LCD and/or lens assy cracked, reason, to much HEAT! The blue is the darkest color and hold the most heat, so it goes first, always! In some cases it’s only the lens, however most of the time LCD is damage to. Parts are available, however install and alignment is timely. Quick fix is the complete light engine, which for model# E44W46LCD is part# 3141VSN916C, which customer cost is $1,449.27, wholesale for about $1,065.21. Rebuilt, if you can find it around 850.00 to 950.00. However the rebuilt does not always look as good as factory. My advice, TRASH set. This part will fail again in about 3 to 4 years, unless you watch a lot of white video. Remember, on a black or dark picture, all three LCD are blocking 100% of the light, causing extreme heat within the light engine. It’s a bad design.
TV Tech
Posted on Aug 11, 2008
2 Suggested Answers
Luvlee
  • 59 Answers
SOURCE: yellow haze
The blue filter is burnt out. A very common problem in Zenith DLPs. There are 3 color filters, 1 blue (a pinkish color), 1 green (a grayish brown) and 1 red (it is red) they give you your colors for you picture. This is a simple fix.
Posted on Mar 24, 2008
I changed the LCD lamp, but there is still a yellow haze.
The yellow haze is the result of the blue polarizer burnt-in, you will find it sitting in front of the dlp chip.
Mar 20, 2009 | Zenith E44W46LCD 44" Rear Projection...
Replacement Filter for LCD TV
hey there yeah you are right your LCD is brunt out, to be honest with you I don't think they sale just the LCD chips you have to buy the OPTICAL BLOCK to fix this problem good luck.
Dec 04, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow Haze
If your model number is E44W46LCD Rear Projection , yes this will should fix your problem and you can do it yourself. Just be careful with the LCD cube that is beside you color filters, it is very fragile and hard to get.
Mar 24, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow haze
Hi...the yellow haze is probably the blue filter is burnt and needs replaced. This is very common in Zeniths. There are 3 color filters in the Zeniths blue (pinkish in color), green (grayish in color) and the red (it is red). The #1 problem in this TV is the blue filter is burnt and it is an easy fix. It could also be the LCD cube is bad. I would try the blue filter replacement first. It will probably do the trick.
Yellow haze
Mar 23, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow Haze Center Screen
Mar 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow haze and no picture
sounds like you have a bad optical block, very costly but the manufacture of these is LG and they have a recall program on certain problems is this model you may want to give them a call and see if yours might be covered.
Mar 01, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith D60WLCD with blue haze over entire picture
throw the set away!the part required to repair the set is the optical engine.Zenith made alot of these sets with defective engine assemblies in wich the lcd filters burn,which cannot be replaced.The labor is also silly.Theunitrequires a complete teardown for replacment.You could buy a very nice new set for the repair bill
Feb 20, 2007 | Zenith D60WLCD 60" Rear Projection...
Yellow haze in center of screen
Typically caused by a defective light engine. Part is over $1000 last time I checked on it. Could also be caused by a bad "digital board". I've seen this symptom more than once on this set.
Sep 26, 2006 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
774 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
