Question about JVC AM FM CD DET FACE CAR STEREO
Both +12 are connected
If switched +12 v IS connected and head set only accepts or ejects cds what could the problem be at that point?
  • wssimons22 Jul 16, 2008
    it was a blown fuse!
    Sergeant:
  • 300 Answers
If you can confirm that the "always on" 12v is connected to the deck properly and the turn-on lead for the deck is tied into either the ignition or is always tied to 12v, the only other thing I can think of is an issue internal to the deck itself. Usually, though, it's the wiring that gets people. Normally, you don't connect switched 12v to the deck, as it doesn't always have enough current to run it. I wish I could be more help! If there was an error code being displayed, that might be different.
Posted on Jul 14, 2008
  • Tygh Duval
    Tygh Duval Jul 16, 2008
    A blown fuse on the +12V? It's odd that the deck would do anything at all with a blown fuse on the always-on +12V. But glad it's fixed, nonetheless!
KDC 4547UB wont accept or play cds
plz me to clear the solve problem
Mar 20, 2012 | Kenwood Car Audio & Video
C/Audio Azur 640C Cd player rejects discs
the set is not loading because the loading action is not getting compplete. please look into the loading drive and correct the loading , check on the drive. if after it had loaded the cd is not loading the drive then check also onthe belt drive, clean the lens of the optical drive because if so it will not read and so stop action.
change the head if the cd is not turning or if it totate and not reading. Helpful? Good day
Jul 14, 2010 | Cambridge Audio Azur 640A Amplifier
My cds won't play and they will not eject. I have an in-trunk cd changer.
If your radio works and you press mode .Does head unit recognize cd,s
It should display no cd,s cd error etc
The reason i ask this is to confirm that connection is ok to stacker
To eject PRESS AND HOLD eject button,insert credit card under cartridge,push fully in and move left/right untill eject
This will locate micro switch,so you can check discs
Jan 25, 2010 | 2004 Mitsubishi Endeavor
My Phase Linear UV7il accept only some CD's
the head unit is not reading due to incompatibility with thebrand or type of disck
Dec 29, 2009 | Car Audio & Video
Cd player in ford expedition quit showing CD
If you can not eject cartridge
Press and HOLD eject button insert credit card or similar under cartridge.Push firmly in and move left to right untill it ejects,this will locate micro switch.
The fuse is located on the back of the stacker,this is ok because your head unit recognizes stacker.
Nov 14, 2009 | 2003 Ford Expedition
Condensation please wait constantly appears on the screen unable to do anything the camera seems to shut itself down it wont even let me load a tape in.it wont record playback nothing.
There is a "dew" sensor inside that is preventing the unit from accepting the tape. This is a safety feature to prevent damage to the tape. If there is any moisture inside, the tape will stick to the heads and get damaged. Open up the unit (eject) and point a hair dryer toward the opening with the dryer about 12" away. Let the warm air flow for 10 minutes or so and try the camera again. If that failes to resolve the problem, then either the sensor is defective or the connections to it are defective and the camera should see a servicer for repair.
Good luck,
Dan
Nov 05, 2009 | JVC GR-D70EK Mini DV Digital Camcorder
Error with Dual Head Unit
your lazor might be dirty or bad. try a disk cleaner.
Aug 19, 2009 | Car Audio & Video
Bose 6 cd changer factory installed will not function.
Some people with this issue have had some sucess disconnecting the negative battery cable for 10 minutes to reset the stereo. After re-connecting the battery, the stereo should reset and the error message should clear at which point the CD player should also function. Apart from this, a service call at a dealer or a car stereo repair specialist are the only alternatives. Best of luck.
Greg
Jun 14, 2009 | 2002 GMC Envoy
JVC Car Stereo
The head unit should have two separate +12V connections: One that goes to a switched 12V power that is switched on/off via the ignition and one that is always energized at +12V. If the head unit's switched +12V lead is not connected, the unit will not turn on (except for when +12V is first applied to the "always on" lead, in which case it will immediately eject the CD). Please respond if this is not the issue. Hope this helps!
Mar 05, 2008 | JVC AM FM CD DET FACE CAR STEREO
Jensen vm9311ts problem
The player thiinks the CD is still in the player. you have a shorted or open sensor. Usually thee players have 3 phto sensors to tell the controller that a Disc is inserted , or ejected or present. Sometimes a wire or piece of lint covers a sensor and makes the controller think the CD is still there. Get you a can of Air from Radio Shack and blow out the DVD drive You might get lucky and this do the job.
Nov 30, 2007 | Jensen VM9510 Car DVD Player
JVC AM FM CD DET FACE CAR STEREO Logo
62 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
