Question about Whirlpool GS460 Gas Kitchen Range
Power failier when the power goes out my stove and oven won't work the display code shows PF, then goes blank. the light will come on showing the burners or on but they will not heat up. The oven temperature will display but the oven will not heat up. I have unplugged the stove and plugged it back in but this does not work.
  • mistysimmons Jul 13, 2008
    I reset the clock, still not working. thank you though
    Scholar:
  • 148 Answers
Beleive it or not set the clock,I work at an apartment complex and the cleaner always unplugs my stoves to clean behind ,everytime I plug back in PF,Just set the clock hours and minutes,Its just telling you you lost power incase you had something cooking in the oven,you wont think that your oven is broken,and also so it doesnt start automatically by it self please rate this solution thanks
Posted on Jul 13, 2008
I just hit "start" and it goes back to the time.
Posted on Aug 22, 2008
This is exactly right, when your control shows PF, this is not a fault mode but only indication that your controller went out of power. It could be due to a real power failure or be caused by the bimetal switch made to protect controller from excessive heat.
When you see PF, simply apply on the cancel button and it should be ok.
If this occured after self cleaning cycle, I would check the vents for possible clugging.
Posted on Jul 27, 2008
I had a power outage and now my kenmore ultra bake glass top stove, has no power to oven.only when i hold cancel button for few secs"F2EO" shows up on screen. 4 burners still work,along wif oven light
The error code E0-F2 indicates that your touchpad has a stuck key. You might try disconnecting the electricity from the range and pushing and releasing the buttons on the touchpad several times. Be aware as you push them of any button that feels different. If you notice one that is stiffer or just doesn't feel like the others, give it several more pushes. Worst case scenario, you will need to replace the touchpad.
Jan 19, 2018 | Kenmore Kitchen Ranges
Maytag cwe4800acb oven shuts off and display goes blank during heating
Display on maytag oven 8114p471-60 went blank - Fixya
www.fixya.com/.../t16018814-display_maytag_oven_8114p471_60_we...
Jan 20, 2013 - Stove top electric ignition still works fine, so there is power going to the .... maytag cwe4800acb oven shuts off and display goes blank during .
Oct 10, 2015 | Maytag CWE4800ACB 2.6 cu. ft. 24" Single...
My kenmore stove is showing f11 after i did a cleaning cycle and i can not unlock the stove top but the door to the oven unlocked. after unplugging it now shows the clock needing to be set and the pf on it...
F11= problem communicating with display
Suggest you unplug unit, peel off front of display and clean this and contacts thoroughly.
Replace - all should be good.
Feb 08, 2018 | Kenmore Kitchen Ranges
Red light on stove surface is lite up red and code pf is on display
"PF" displayed on the control:
A temporary power failure has been detected. Press the Stop/Clear keypad to reset your control. You may need to reset your clock.
Apr 04, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
We had a power failure and Kenmore stove showed pf and now loc. cannot get burners to turn on and cannot get loc off.
If you have a power failure or a brown out, it sends a very powerful current through the unit. Please keep in mind that these units are not protected against any surges. If you have a display, that means you have power. Unfortunately, the clock/timer contains relays that control the elements, the oven, etc. You will need to replace the clock to get it running again.
Mar 13, 2014 | Kenmore Stove / Oven / Range Bake Element...
Whirlpool stove pf
A pf code usually shows up if the power to the stove has been interrupted for a short time. It is usually cleared by setting the clock or setting the oven or broil.
Nov 20, 2013 | Ovens
PF code
Depending on manufacturer and model, PF can mean a number of things. On my stove, PF simply indicates "Power Fail" Yours may, too. You can clear this generally by updating the clock display. To verify that PF does indeed mean power fail for your stove, simply shut off the power for the cicuit than supplies the stove. This can be either circuit breaker or fuses. Turn the power back on after 5 or more seconds and if it displays PF again, you know it means power fail.
Otherwise, please provide the manufacturer and model of you stove for an answer.
Jul 02, 2012 | Ovens
Stove-top works, oven showing all 888888 across the screen
You're stove must be perfectly fine, but the thing displaying all those options may have a problem. Try to get this fixed as soon as possible.
Jan 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool GS460 Gas Kitchen Range Logo
806 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
