Verizon DVR HD Cable Box
I'm trying to record off of my Verizon DVR Box onto a DVD recorder. I'm only getting black recorded onto the DVD. How do I wire this properly to record ???
Thanks !!
  • r8dir Aug 15, 2008
    I need to know how to record from the verizon dvr to a dvd re: what to buy and how to hook it up.
    Thanks
Press the red button tha has a text of REC
Posted on Aug 03, 2008
I have surroundsound. I have dish network with hd dvr. I have a sony bravia hd tv. I have a dvd player, and cd player. I have a magnavox dvd recorder. I want to record from my dvr to my dvd recorder. ...
To get the functionality you're looking for you'll need to to take the cable running from your DVR output and connect it to the input on your DVD recorder. Next you want to connect a cable from your DVD recorder output and connect it to your TV. If this is an HD set up you want to use HD Cables for all of the connections.
Daniel Busa
DISH Network Customer Service
Jan 03, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
This dvd recorder worked PERFECTLY when I had digatal cable. As soon as I up graded to HD with a HD box from comcast, I cannot get the recorder to record anything. I hooked it up the same way as I did with...
The HD box from your cable company only sends High Definition Video signal which DVD does not support. Your DVD recorder "CANNOT RECORD THIS PICTURE" because it can not process (see) the High Definition (HD) Signal.
To record from an HD reviver you would need a HD recorder (Blu-ray) very expensive The standard practice for recording from a HD cable receiver id to use an DVR here is a link to one for about $100 some models will have a standard video output you could connect your dvd recorder to.
http://www.google.com/products/catalog?q=HD+Dvr&oe=utf-8&client=firefox-a&hl=en&cid=15241578777457062393&ei=puGPTNuoFIm4iwSJ2s1h&sa=title&ved=0CBcQ8wIwATgA#p
Sep 14, 2010 | Sony RDR-GX330
I have a Toshiba D-VR16. How do I copy a VHS video onto a CD?
Just put the tape and a blank cd in and just press the Copy from the case.
Aug 10, 2010 | Toshiba Televison & Video
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
Have magnavox dvd recorder record direcTV DVR programs w/ hdtv
I am unfamiliar with this unit.
If you have scart connecters on both, connect av2 on the tv to av in on the recorder. set the recorder to record from av source.
You should now record a program, I think the static is the fact that composite is out from the dvd only, not an input, and in on the tv, not an output.
Sep 04, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Jan 17, 2009 | Toshiba DVR610 DVD Recorder/VCR
DVD Menu selection not available from Setup Menu
I don't have movies from premium channels, but do have cable HD channels. When I got the message re not recording in +VR, I copied from DVR to HD in PhilipsDVD-R and then dubbed to DVD.
Dec 05, 2008 | Televison & Video
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Recording from cable dvr
You have to hook up an AV cable from the box to the DVDR.. Out on the cable box to IN on the DVD player.
Then put your DVD player on AV1 - ( you can do this by pressing the INPUT SEL button on the DVDR remote)
Then put the Cable box on whatever channel you want to record. And press the record button on the DVDR and you will record whatever channel the cable box is on
If you can't get to AV1 then you have to disable cable box control (menu>setup>system>cable box control>off
Jan 12, 2008 | Samsung DVD-VR357
Televison & Video Logo
578 people viewed this question
Top Televison & Video Experts
Electro Med Services...
