Question about GE Washing Machines
Washer not washing. drum not spinning on drain and spin cycle. water goes in. clothes remain very soggy. water leaking from under washer. clothes still dirty. whites.
  • mudhead Jul 13, 2008
    this is an addition to my original report.  I've submitted my credit card information twice.
    Genius:
  • 1,847 Answers
Wht is the model no #, is that a front load one?
Posted on Jul 13, 2008
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
After spin cycle clothes too soggy
Please see the answer we gave some moments ago.
Feb 08, 2015 | Washing Machines
My washing machine keeps getting water in it after the cycle is over. This morning I came in and my empty washer was filled with water and had overflowed onto the floor. Help! There are also times when...
mine also remains wet and soggy, even after the spin cycle. However, I have not, as of yet, (and hopefully won't) begin having overflow problems.
Mine is jumping around the laundry room - as though in an unbalanced cycle. We discovered that one of the "feet" that the washer stands on needs to be adjusted, upward or down, so that the washer stands balanced and evenly. The "foot" does not make contact, and when we turn it to change its height, it just goes in circles without changing height.
Mar 09, 2010 | Whirlpool Washing Machines
After the final spin cycle, my clothes are still wet.
Check these out:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
  • Check your washer for a frozen pulley. Remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, it's frozen, replace it.
  • If the water that pumps out of the machine goes back after the spin cycle, your washer is siphoning the water from a laundry tub that has a slow drain back into the washer. The usual remedy for this is to improve the draining of the laundry tub.
  • Also check for these problems:
  1. If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
  2. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 21, 2009 | Hoover HTC243 Top Load Washer
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
LAT9604AAE No agitation but drum spins and drains water
cold possibly be just the agaitor but odds are u need a transmisson not worth repair
May 20, 2009 | Maytag PAV2300 Top Load Washer
Amana nav5800aww water on floor after spin cycle
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
May 10, 2009 | Amana NAV5800A Top Load Washer
Neptune washer
If the water is draining out o.k. then either there is no signal from the water level pressure switch, no signal from the control board or a problem with the Spin windings.
Mar 11, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Rinse cycle spinning... clothes still soaked
It sounds like your washer is not going through it's neutral drain. After agitation, your washer should pause and drain for around 90 seconds to pump out the water before spin. Check this out by starting a wash with a small screw driver holding the lid switch down. This will allow you to observe whether or not it's going through it's neutral drain. If not, it's a transmission problem. The trans is covered under warranty for 5 years. You may also want to check the pump to see if it's gunked up. Catriver..post back.
Dec 04, 2006 | Kenmore 24982 Top Load Washer
Washing Machines Logo
61 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
