Question about KitchenAid KHMS145KSS Microwave Oven
Turns on randomly Reads: PAN and then counts down from 3 minutes
Unit is only a couple of years old. Worked fine until recently. Displays clock and then randomly turns on reads: PAN and counts down from 3 minutes and then continiously beeps to the point I have to disconnect the unit...Any suggestions. Couldn't find anything in the manaul?
  • Anonymous Jul 15, 2008
    mine does the same thing!
  • KitchenAid Master
  • 9,086 Answers
From the owner's manual found here or here:
"Touch PAN HEAT once. Pan will preheat for 3 minutes."
Sounds like it's doing it on its own due to a failing keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 19, 2008
Intermittent Power Loss
Take the unit apart and carefully inspect the wires under the keypad...short of that..junk it and get a new one. It seems they just don't make things the way tey used to.
Nov 19, 2013 | Samsung SMH9187 Microwave Oven
Timer runs 10 times speed
Try to power by locating circuit breaker that powers that area?
Nov 05, 2012 | KitchenAid KCMS2055SSS Microwave Oven
Microwave starts on its own and displays PAN
You have a shorting membrane keypad.
I'm contacting you directly.
May 22, 2010 | KitchenAid KHMS155L Microwave Oven
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
Microwave turns on and counts down but won't heat up/cook
Ok just figured this out! It is a problem with the alignment on the lower door switch. I took the cabinet off and lifted up on the door switch slightly and voila! It works. You could probably fix this without taking it apart, just lift up on the door ever so slightly. I hope this works for you.
Jan 13, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave not working
Sadly, we hear of this over and over.
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details are in their bulletin here. Even if your model is not on the list, the same problem can occur, requiring a kit.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
They may send you a replacement magnetron. GE Customer Service is here.
Nov 25, 2008 | Microwave Ovens
Microwave turns on randomly beeps intermittently displays PAN
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it and please reply back with your model number so we can help you.
Sep 07, 2008 | KitchenAid Microwave Ovens
Sensor Error, Funny Smell and Noise
On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
If none of these conditions apply to your situation, then you may have a defective sensor and/or magnetron.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Sep 02, 2008 | Microwave Ovens
KitchenAid KHMS145KSS Microwave Oven Logo
60 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
