Question about Whirlpool Kitchen Ranges
Oven throws a E0 F3 error code - Whirlpool Kitchen Ranges
  • 1 more comment
  • Anonymous Oct 23, 2008
    E0 F3 error on Whirlpool range
  • mhvddspc Jan 11, 2009
    E0 F3 error code ususally means that the sensor needs replacing or has a short.
  • Aggravation Jan 19, 2009
    Is this also the same problem in the non-smooth top ranges? My stove put itself on the 'self clean' and would not open, and now since I finally got it open it is showing the F3 E0 code and doesn't do anything. Does anyone know why?
Most likely the temperature probe. My fan continued to run until I disconnected my temperature probe. Unscrew the 2 screws holding the probe in place and pull on it until the plastic connector male/female comes through the hole in the back of the oven. Disconnect the connector being careful not to let the female fitting slip back into the hole. Once I disconnected the temperature probe the fan stopped running. I believe a new temp probe/sensor will correct the F3 E0 error and correct my Bake function. The oven wouldn't preheat or turn on. The Broil and Clean functions worked but not the Bake function.
Posted on Mar 13, 2009
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Jul 31, 2014 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I have a kenmore ultra bake, model #665 75022101 and the oven doesnt work the code E0-F3 comes up. i have the manual and have tried what they said to do but it doesnt work. i have bought a new sensor
The error code message F3 E0 indicates an open oven sensor circuit. This is the component that regulates the oven temperature.
First disconnect electrical power to the range. Pull the range out & remove the rear panel to the control area. Unplug the 2 violet wires on P3 5-6. You will need to have a meter for testing, set the meter to read ohms (resistance). Place the leads from the multimeter across the 2 violet wires, the meter should read 1080ohms if the sensor is good. If you do not get the correct reading you will need to replace the oven temp sensor.
The oven temp sensor is mounted to the inside of the oven cavity. You will need to remove the lower section of the rear panel to access the sensor connector. Unplug the sensor & slide it back into the oven cavity to remove & replace.
Taken from...
http://www.managemylife.com/mmh/questions/120802-kenmore-range-displaying-e0-f3-error-code
Jan 12, 2012 | Ovens
F2 &F3 error codes, oven keeps beeping, I already tried turning off circuit breaker did not solve problem
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
connection (keypad connects to control board).
2. Press CANCEL. If error code
returns after 60 seconds, replace keypad (also called touch pad or membrane
switch). Some models incorporate keypad in to control board as one unit. In this
case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open F3 - E0 Oven temperature sensor (RTD) opened (upper oven,
if double oven) Replace Oven temperature
sensor (RTD)
Note: Applies to all F3-E...
codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
oven, if double oven) F3 - E2 Oven temperature is too high (Cook
mode) F3 - E3 Oven temperature is too high (Clean
mode) F3 - E4 Oven temperature sensor (RTD) opened (lower oven,
if double oven) F3 - E5 Oven temperature sensor (RTD) shorted (lower
oven, if double oven) F3 - E6 Warming drawer sensor open F3 - E7 Warming drawer sensor
shorted
Dec 20, 2010 | Whirlpool Accubake RF362LXTT Electric...
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Whirlpool Gold Accubake Duo. ''E4 - F3'' or ''E0 - F3''
HI. These codes are an indication of oven temperature sensor failure. The sensor is damaged. This will not allow for proper operations. The affected part must be replaced, asap.
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner.It will look like a 4 inch long slender probe. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Dec 28, 2009 | Kitchen Ranges
F2e0 error on stove
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Whirlpool RF196LX Smooth Top Range
4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Oct 21, 2007 | Kitchen Ranges
Kitchen Ranges Logo
427 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
