Question about Canon Pixma MP480 All-In-One InkJet Printer
My canon pixma 480 has thin horizontal lines. tried cleaning and deep cleaning where is the head alignment tool?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 53 Answers
The instructions as copied from the Pixma 480 "onscreen manual." (Only the text -- not the images -- could be pasted into the solution. Hope you can follow the text.) Steve G.
Prepare 2 sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and load 2 sheets of A4 or Letter-sized plain paper in the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Print the print head alignment pattern.
- Press the Menu button.
- Select Maintenance, and press the OK button.
- Select Print head alignment, and press the OK button.
Note: To print the current head position adjustment values, select Head alignment print in the Maintenance menu and press the OK button. See Selecting Menus on the Top Menu Screen.)
- Select Yes, and press the OK button to print alignment sheet.
- Check the pattern is printed correctly, select Yes and press OK button.
- Confirm the displayed message and press the OK button.
The Print head alignment screen appears.
4. Adjust the print head position.
- Check the printed patterns, and use the (Left) or (Right) button to select the number of the pattern that has the least noticeable streaks for column A.
Note: If it is difficult to select the best pattern, select the pattern that has the least noticeable white streaks.
(A) Less noticeable vertical white streaks
(B) Noticeable vertical white streaks
(C) Less noticeable horizontal white streaks
(D) Noticeable horizontal white streaks
- Repeat the same procedure to input the pattern number for each column from B to L, then press the OK button.
- Select Yes to continue printing, and press the OK button.
- The second page of print head alignment sheet will be printed.
- Confirm the message for print head alignment, and press the OK button.
- Check the printed patterns and use the (Left) or (Right) button to input the number of the pattern that has the least noticeable horizontal streaks for column M.
- Repeat the same procedure to input the pattern number for each column from N to R, and press the OK button.
Posted on Jan 12, 2011
SOURCE:
Canon PIXMA MP510 : When I print something in colour, I get alternating dark and light 3mm lines printed horizontally down the page. I've tried cleaning, deep cleaning and realigning the print...
Hello
what you need is to clean, you need to clean the prnt head and ink cell, you open the top part let the ink carrier move to the center then UNPLUG the power cord ,now you can easily clean ink cell.
Jun 29, 2011 | Canon PIXMA MP510 All-In-One InkJet...
I HAVE LINES APPEARING ON COLOURED PRINTS
try cleaning the head with window cleaner and dry the head thoroughly
Jun 05, 2010 | Canon PIXMA iP3300 InkJet Photo Printer
Put new black canon 3-e ink in canon Pixma ip 5000 black line of print have a white horizontal stripe through center. I don't seem to have a repair utility t o clean heads and align. Mac OS 10.4.11
The clean heads option should be in the Preferences/Maintenance tab where you go to do other things, e.g. alignment, ink counter reset, etc. If you cannot see this, you mmay need to reinstall the driver for the printer. You could also ask Canon. Finally, if the catridge is a refill or compatible, try a genuine Canon black cartridge.
Apr 25, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
Canon Pixma MP130 printing lines through pictures etc
I'd say it's probably the printer driver. Uninstal and reinstal it or update it. Printer drivers are a comon cause of printing faults.
Aug 16, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Horizontal printing not straight
Have you cleaned or replaced the printhead recently?
Mar 21, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon pixma ip500 horizontal bands of non-printing areas
Hi it's Gill again. I've been looking around more on the net and I think the problem is our printers need new printheads which I'm told are spare parts easy to change. Hope this helps. Gill
Mar 18, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
I am getting white horizontal lines through my color photos when I print them. Is there an adjustment that I need to make in order to eliminate these lines for a clear sharp color photograph?
see owners manual PIXMA MX700 Quick Start Guide pages 85-93,:Nozzle Check
Pattern,Print Head Cleaning,Print Head Deep Cleaning and Aligning The Print Head
Mar 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Horizontal lines through my printed photos
Are you sure your ink is not on the verge of finishing? Try changing the colour ink and print again. Sometimes I take the cartridge out, shake the ink down just in the same flashing motion as I do my pen, then replace it. You may try that.
Jan 20, 2009 | Canon PIXMA MP970 InkJet Printer
Canon Pixma MP480 All-In-One InkJet Printer Logo
697 people viewed this question
Clive
Clive
old marine
old marine
