Question about LG Televison & Video
When i turn my RH277H on the disc tray opens and closes forever
  • Anonymous Dec 07, 2008
    i have exactly the same problem. have you manage to solve it ?
I had the same problem and a tried the following, which worked for me:
Try this:
Unplug the recorder and leave it for a while unplugged.
Plug it again.
Pressing continuously the STOP button, press POWER.
Wait till it turns on, and then release the buttons.
GOOD LUCK!!!
Xenios
Posted on May 03, 2009
  • 4 Answers
I tried the solution documented at
http://www.ifndef.altervista.org/index_eng.html
3:rd Loader repairing
This works I have done it myself
Posted on Mar 21, 2009
How do I unjam a disc stuck in the 5xCD tray of a Sony DAV-C770 compact AV system?
If you experience difficulty with the disc tray opening or closing, follow these steps to try to resolve the issue.
  1. Turn off the power to the disc player or the stereo system, if the disc player does not have a separate POWER button.
  2. Unplug the power cord from the AC outlet.
  3. Verify there is nothing is blocking the tray from opening or closing.
  4. Let the disc player or the stereo system remain without power for approximately one minute.
  5. Plug the power cord back into the AC outlet.
  6. Turn on the power to the disc player or stereo system.
  7. Attempt to open or close the disc drawer or tray.
If the issue is still unresolved, service may be required.
this is direct from sony hope it helps
Dec 31, 2014 | Sony DAV-C770 System
Disc tray will not open?
There could be a disc jammed in the tray. The humming sound is the tray open/close motor trying to work
Jan 16, 2013 | Bose Av3-2-1 Series Ii Media Center...
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      NOTES:
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
My xbox will not read discs it just says open tray
I found a solution that works for me after a long period of time with this problem.
Get an air spray canister (just compressed air), open your Xbox's game tray, take the disc out, then spray the air along the tray, moving side to side inside the Xbox. You may want to spray into the vents, too, just to be sure.
This worked for me, and it was the only thing that worked for me. I had already tried hitting the console with the controller (gently), and doing the stuff Microsoft recommends etc.
If that doesn't work, you could try gently knocking the top of the Xbox with your conroller, when you put the disc in, as I've heard that works for some people.
Another thing that works for some people is taking the disc out, closing the tray, then when it goes to Open Tray, open the tray, put the disc back in and then closing the tray again.
Jun 17, 2010 | Microsoft Xbox 360 Console
My Samsung BD-P1400 is frozen on "load" and disc tray won't open
My player worked fine couple of days ago, then last night when powered up, message was "load" and it stayed like this forever, and tray open would not work. Tried everything, nothing worked. Left unplugged from power for 24 hrs and bingo everything worked as should. I suspect that the unit is still trying to load info from last disc which I stopped in the middle of some bonus material, even though the disc was no longer in the tray.
Dec 26, 2008 | Samsung BD-P1400 Blu-Ray Player
Disc tray will not close
Unplug your 360 from the main power source and make sure there's is nothing that may be preventing the tray from closing completly
Nov 02, 2008 | Microsoft Xbox 360 Console
Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Dec 03, 2007 | Sony DVP-NC650V Multi-disc DVD Player
Xbox does not read discs.
Getting to the dashboard screen is a good thing but still cannot rule out a bad circuit board or power supply. All the symptoms point to a bad DVD drive but the opening/closing by itself do indicate a problem with the microprocessor. Can you turn the power on and off with the small button?? If not, would definitely suspect bad board.
Aug 16, 2006 | Microsoft Xbox Console
Televison & Video Logo
302 people viewed this question
Computer Repairing
Computer Repairing
