Question about IBM Infoprint 1412 Laser Printer
Factory reset for IBM Infoprint 1412
I have turned off the web GUI on the printer and believe I can get it back by doing a factory reset on the unit, does anyone know how to do this?
Cheers, Chris.
wilddj@hotmail.com
  • 21 Answers
Open toner door, press and hold stop button whilst powering on printer. or Telnet into printer i.e telnet <ip addr> then use command 'set http on' then 'save'
Posted on Jul 08, 2009
5 Suggested Answers
SOURCE: infoprint 1412 on windows vista
I have the same problem with my 1412, if you find a driver please emial me.
Posted on Mar 19, 2008
SOURCE: resetting IBM infoprint 1552 maintenance counter
Go Here: it's a PDF file which explains how to reset the printer's maintenance count.
http://www.marketpoint.com/files/pdfs/mk_ibm_1532.pdf
Posted on May 15, 2008
  • 4 Answers
SOURCE: want to reset my IBM Infoprint 1412
• Press and hold Cancel until all of the lights come on to reset the printer.
Posted on Jul 15, 2009
LHeruska
  • 94 Answers
SOURCE: Ibm infoprint reseter
Here is a procedure I would like you to do to reset the light:
1-Power the printer on and get it to the Ready state (i.e. the light on the operator panel is on)
2-With the printer on and in the Ready state, open the front cover
3-Press and hold the Cancel button until all of the lights begin flashing up and down.
4-Release the Cancel button and close the door. The photoconductor count should now be reset
To confirm that the photoconductor page count has been reset, it is recommended that you print a
menu settings page and check the photoconductor level. Do the following:
1.With the printer at the Ready status, press the Continue button once. The Ready
light will begin flashing and one or two pages will print out.
2. Look for a section labeled Cartridge Information and locate the word Photoconductor
under this heading.
3. Confirm that the photoconductor level reading is either OK or close to 100%.
4. If the reading is low, try printing 10 - 20 pages.
5. Print the menu settings page(s) again.
6. Confirm that the photoconductor level reading is OK or close to 100%.
7. If the photoconductor reading is still low, there is a second, more detailed, procedure you
can perform to reset the count.
8. If the reading is still low after both procedures have been attempted, the printer may require service
Posted on Feb 05, 2010
Toner light is blinking but there is a new toner cartridge in it
  1. Press and hold Cancel until all the lights will turn on (this will perform a basic reset of the printer)
  2. With the cartridge door opened power up the unit (this should be factory reset)
However if the cartridge was refilled it is possible that the chipset was not properly resetted if at all so see the store were it was refilled.
Feb 13, 2015 | IBM Infoprint 1412 Laser Printer
Reset factory settings on Infoprint 1312
To reset IBM Infoprint 1312 to factory settings, do following:
1. disconnect USB and network cables
2. switch power button to OFF
3. open toner door
4. press and hold both buttons (continue+cancel)
5. while holding buttons, switch power button to ON
6. keep holding buttons until printer initialization is finished (LED error is on)
7. close toner door
8. switch power button to OFF
Connecting printer in network:
Now you can connect printer with network cable, make sure DHCP works in your network. Switch power button to ON. Printer initialization should also obtain IP address from DHCP.
You can look in your router DHCP clients list or you can try to use software delivered with printer to find printer in network :)
When you go to IP of printer via browser, it will allow you to change some settings. Username to login is usually MarkNet, password is yours :)
This is all my personal exprience, it definitely works for this particular network printer :)
Mar 13, 2012 | IBM Infoprint 1312 Laser Printer
Driver for ibm infoprint 1412 win 7
Use this link to download.
http://www.infoprintsolutionscompany.com/internet/dcfdata.nsf/vwWeb/P4000925
Then install and on the properties change the name of the generic printer to IBM Infoprint 1412. It worked for me. Good luck
Nov 24, 2011 | IBM Infoprint 1412 Laser Printer
I want to have the driver for ibm infoprint 1412 for windows 7 please. thanks
You can download the IBM InfoPrint 1xxx AIXPrint Driver from their supportWEB site.
Please click on this link and select your model printer to download:- http://www-01.ibm.com/support/docview.wss?rs=95&context=SRATEW&dc=D400&uid=psd1P4000313&loc=en_US&cs=utf-8&lang=en
Mar 04, 2011 | IBM Infoprint 1412 Laser Printer
How reset photoconductor ibm infoprint ibm1512 thank you
The instructions for IBM Infoprint 1412/1512 printer's photoconductor is the same as the Lexmark E342.
The instructions are located here: http://support.lexmark.com/index?page=content&id=HO2564&locale=en&userlocale=EN_US
Recap of Instructions:
To Reset Photoconductor page count:
1. Turn off printer
2. Press and hold the Select and Return buttons at the same time on the panel and turn the printer on (continue holding down buttons until printer screen displays "Performing Self Test" or "CONFIG MENU").
3. If "Reset PC Cnt" does not appear on screen, press the left or right menu button until it appears.
4. Press "Select" and the message "Resettting PC Cnt Value" should briefly appear indicating the page count is reset.
5. Turn off printer when "CONFIG MENU" appears again.
6. Wait 5 or more seconds and turn back on. Done.
7. It is suggested to check and verify that the PC Count is reset by printing a menu setting page:
a. Press left or right menu buttons until you see "Utilities Menu" and press "Select".
b. Press left or right menu button until you see "Print Menus" and press "Select".
c. This should print out the information. Look for "Cartridge Info" and the word "Photoconductor". It should indicate "OK" or close to 100%.
d. If not showing "OK", print 10-20 pages and Print Menu again to check. If still not, reset PC again and check again.
Jan 13, 2011 | IBM Infoprint 1512 Laser Printer
Where to download the IBM 1412 printer driver for windows 7?
I have an IBM Infoprinter 1412 and Windows 7. I'm not clear on the answers here - is there a link for a driver I can download that will make this printer work?? Please provide link! Thank you!!
Dec 22, 2010 | IBM Infoprint 1412 Laser Printer
Want to reset my IBM Infoprint 1412
Mar 12, 2009 | IBM Infoprint 1412n Laser Printer
Poor print quality
you need to replace the Drum otherwise known as the photoconductor I believe the part number is 75P5712 - your toner cartridge actually seats into the PC kit.
Dec 12, 2008 | IBM Infoprint 1412 Laser Printer
under this heading.
Apr 06, 2008 | IBM Infoprint 1412 Laser Printer
Infoprint 1412 on windows vista
Mar 14, 2008 | IBM Infoprint 1412 Laser Printer
IBM Infoprint 1412 Laser Printer Logo
1,336 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
