Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Frigadaire dishwasher Water pools in the bottom of the dishwasher and becomes stagnant when not in use
  • 148 Answers
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
please rate my solution thanks
Posted on Jul 13, 2008
I have a fisher and paykel dishwasher. 2drawers. Just ran. Stinks now and when I take out bottom stuff, stinky stagnant water inside
Do a hot wash with 2 cups of bleach in the dishwasher. No other chemicals, just bleach. It will kill the mold and clean it.
Aug 18, 2017 | Fisher and Paykel Dishwashers
Odd odor coming out of dishwasher upon opening it. Smells like rotten milk. What is the best cleaning solution?
After a dishwasher is installed the hose rarely comes to mind - unless a problem occurs and a repair person comes out to inspect the job. If the hose was installed improperly, or if it is lying in a position that does not let it drain, stagnant water will create a bad smell. Examine the hose that is probably inside the kitchen cabinet beneath the sink. If the hose is lying in the bottom of the cabinet, it is probably full of water. A film begins to form inside the hose and the odor begins to grow. The next time the dishwasher is used, the stagnant water ends up on dishes, and in the meantime it can cause a bad smell inside of the dishwasher. Hang the hose at an angle on supports in the back of the cabinet. This alone might get rid of the bad smell inside the dishwasher.
Check the Seal
A dirty dishwasher seal can be a source of a bad smell. Before deciding the dishwasher needs to be replaced, check the seal - especially at the bottom. Old food and grime builds up in these areas and can cause a particularly bad smell. Clean it with a solution of diluted bleach and hot soapy water. One teaspoon of bleach for each quart of water is sufficient to kill germs and the odors they create.
NB I decided to add a little bit of vinegar to the machine after I unloaded it. Sure it would smell pretty strong for a while but then the smell would dissipate. Voila! For two weeks now my dishes have not smelled whatsoever.
Jun 23, 2011 | Maytag MDB6709AW Builtin Dishwasher
Frigadaire dishwasher won't drain
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
Apr 13, 2011 | Frigidaire Dishwashers
I have no power to my dishwasher. it is not the breaker and the dishwasher is hard wired. the bottom is full of water. is this a pump issue, or is there other electric parts that could have gone bad?
To answer your question directly the pump is the heart of the unit. With the stagnant water on the bottom your conclusion is correct. I don't know how old the unit is so you will have to out weigh whether it is more economical to purchase a new machine or repair it. My opinion, unless you are going to work on your own unit to replace it.. Good Luck
Jan 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
GE Dishwasher that will not advance cycles
sounds like inlet valve is not opening or water has been turned off or kinked.
Sep 14, 2009 | GE Dishwashers
My dishwasher will not drain. Water is pooled in the washer.
Sometimes the Filter screens in the bottom, can become clogged with food particles. With a few simple houshold tools, you can disassemble it and clean the screens.
Jan 17, 2009 | Frigidaire 24 in. FDBB540 Built-in...
Smells of stagnant water
Had the solution for me and LG doesn't stink anymore.
Aug 23, 2008 | Dishwashers
Bosch Exxcel dishwasher "check light" indicator
**** out the water with a shop vac. Consult manual for self diagnosing keypad codes.
Jun 08, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Water not draining
Usual causes are: 1. Something in the drain path blocked. Symptoms: You can hear the drain pump running at the appropriate bits of the cycle, but if you you open the door the instant the pump stops, there is still a pool of dirty water in the bottom. Solution: Follow the path from strainer through drain pump to drain hose, find and eliminate the blockage. Most likely points are the strainer and the inlet to the pump. Hint: You can identify the drain pump by following the drain hose and seeing what it's attached to. 2. Drain pump broken. Symptoms: Usually, you won't hear the pump running at all at the appropriate times; if it does run, it won't sound right. Solution: Take it off and open it up, see if something is blocking the impellor (in which case, fish it out). Spin the impellor with your fingertips; If it won't turn at all, you need to find out why it has siezed (may be fixable) can you feel it turning the motor (a very magnetic, "flippy" sensation). If you can't, the impellor has probably become unstuck from the shaft. You may be able to glue it on, but this fix is unlikely to last very long. Use a multimeter to measure the resistance of the motor windings. If madly different from a few hundred ohms, again a new motor might be necessary. Hint: The pump motor and impellor can usually be bought separately from the pump housing as a much cheaper unbranded part. 3. Back-siphoning from the waste plumbing. Symptoms: You can hear the drain pump running normally at the appropriate times, and if you open the door the instant the pump stops, the machine appears to be empty, but then quietly fills up with dirty water. Solution: There is meant to be an air break (or in some installations and anti-siphon valve)where the machine's drain hose enters the domestic drainage drainage system. Unblock/unjam this. Hint: After fixing this, run the machine empty on the hottest, longest cycle it has; some of that dirty water may not originally have come from the dishwasher. A.
Apr 21, 2007 | Candy 24 in. CD623 Free-standing...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
126 people viewed this question
Top Frigidaire Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
