Question about Ovens
Ge profile IM curius if you gave me a bad rating,if you did ok,but if someone is voting for you and you didnt give me a bad rating please let me know so I can contact the fix ya team
No I did not give you a bad rating. Actually I just rated you. You were very helpful.
We are going to get the extended warranty as it is $245.00. The part alone that I need is $217.00. Was just hoping is would be a little fix dollar wise and not a big fix.
Thanks so much for your help.
Posted on Jul 13, 2008
I replaced the igniter on the oven and it wont come on know the broiler works did i wire it up wrong model 911-30464200 kennmore wall oven
Hello, Thank You for using FixYa. I will be helping you today.Im sure you wired it correct. There are 3 thermostats behind the control check them for continuity if they are good and you ignitor is wired good and no broken wires then the control is bad
Thank You and please rate my answer if it was helpful..
Jun 20, 2011 | Ovens
F25-get this message. It can be temporarily stopped by adjusting the connections at the motherboard but the error code returns in a couple of weeks. Any advice?
Sorry to read about your problem, I hope this helps you out.
you can try and use contact cleaner, you may have bad connectors or defective/cracked board. either case they will have to be replaced.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | Thermador C301U Electric Single Oven
I have a Char Broil inferred grill. It does not have the auto clean option....what is the best way to clean the grates with? i have heard you cannot use a wire brush on it bc it will mess up the...
you can use oven cleaner, and use a soft plastic brush.
3 Thumbs - Helpful
Jan 05, 2011 | Ovens
My kenmore elite oven is giving me a F30 error message. what is this code?
f 30 is a the oven temperature sensor open, thats the probe in the oven area
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
3 Thumbs - Helpful
Jan 02, 2011 | Kenmore Elite Stainless Steel 40" Dual...
The upper oven on my Tappan Gas double oven is to hot. When set to 300 it ranges up to 350, but when set to 375 it goes up close to 500. I tried to adjust the knob setting but that did not help any...
sounds like you just have a defective heat probe, you did not give a exact model number, which we will need to further help you...
3 Thumbs - Helpful
Dec 31, 2010 | Tappan Ovens
The timer on my double electric cooker seems to be stuck on delay timer. How do I turn it off? Thanks.
try to reset the power on the unit..if that fails and the problem stays..you have bad time or stuck keypad..
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Ovens
My dacor oven light won't go off & the error message says close the door but the oven door is already closed. this is occurring only in the top oven.
you have a defective door switch
Dec 25, 2010 | Dacor Ovens
I am having f3 mag current fault indication in display. I want to know what's the faulty parts and how to detect and solve the problem
Theerror code is for the magnetron/microwave part of the toaster. You will need to have it serviced by someone familiar with the unit, it could be easy and reasonable, if just a fuse blew, but not likely. If the fuse blew, it is 20amps, so something took it out. Call turbo chef, they will get you to the closest service company
Here:http://www.turbochef.com
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | TurboChef TORNADO Electric Oven
How do I re-insert the Thermador oven door so it is properly in place and functional? Issue cropped up when someone cleaning it put too much force on the door and it became unhinged on one side. I was...
this takes alot of practice, really hard to explain..i suggest you call a service company....
Dec 23, 2010 | Jenn-Air JJW8230D Electric Double Oven
I HAVE A FRIGIDAIRE ELECRTIC STOVE,GETIN F2&F3 CODES
Hi, these codes represents a fault within the oven temperature sensor. Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Please rate and god bless:)
Apr 18, 2009 | Ovens
Ovens Logo
62 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
