Where can I purchase a Main Power Supply Board for a Sylvania 6842PE M? Also where can I get info on voltage adjustments needed
  • deslinger Jul 13, 2008
    Found the Board...now need the info!!!
    THANKS
  • 13,433 Answers
Try going directly to the website that was given
http://www.shopjimmy.com/searchparts.cfm?make=Sylvania&t=model&m=6842PE%20A
You see the live help tech support? They should be able to give you the details, Im not sure what kind of adjustments are needed or not. So try that or repost the problem if not solved.
Posted on Jul 13, 2008
    Master:
  • 848 Answers
  • gopinath pasupathy Jul 13, 2008
    just try to use voltage regulator that makes the voltage adjustments automatically ........
Why wont my tv turn on
That problem is usually have 2 causes..Its either power supply board or main board..
Please take this steps on how to determine the problem:
1. Open the back cover.
2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
4. If the power supply output is normal..The problem could be on the main board...
5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope this solution will be helpful..
Thanks for using fixya...
Jun 06, 2012 | Sylvania LC320SS2 TV
It stays in stand by mode power light comes on and then goes off.
Good day!!!
That problem is usually have 2 causes..Its either power supply board or mainboard..
Hope thissolution will be helpful..
Aug 12, 2011 | Sylvania LC225SSX LCD TV
My power comes on for about three seconds then shuts off. do you know what might be causing this?
The power supply of yur television have problem.Theres some leak or shorted parts in the power supply.Need for repair the power supply.
Jul 04, 2011 | Sylvania 6842PE TV
I have a sylvania LC200SL8 which went dead. Repair shop said it needed a new "Mother Board" (pn A7140UH) which I replaced. Still does not work at all. Any suggestions?
Power supply voltage outputs should be check first before anyhting else is replaced. I see that it has one main board which has the tuner, inverter, power supply all in one. What do get right now?
Oct 14, 2010 | Sylvania LC-200SL9 20 in. LCD EDTV
Sylvania 6842pe blew fuse, replaced fuse, and nothing,no lights, noise, nada. replaced power supply board with the chord attattchment and still no power, no lights, and no noise. Was wondering could it be...
Yes,replaced all the boards that related to the power supply.Useally completely dead,it effect all the ICS in the boards,never able to tell which boards.U are not a tv tech.don't do this everyday's will not have skills or any idea which board is dead.
Apr 06, 2010 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
When i turn my 42 inch plasma sylvania on, it makes a sharp high pitched squeal, then shuts off. it does this repeatedly, whats the problem, and how do i fix it?
You have a short on one of the drive boards making the power supply squeal. You will have to unplug each board until the squeal is no longer there. Which ever board it is will have to be replaced. Thanks for using fixya.
Nov 26, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
I was watching t.v. and the screen turn black and the sound was gone as well.and has no power at all
hello, you need to check the power supply board,check for any blown fuses or burned parts.that should be your first step. and if you don't have any repairs skills call the serviceman.
good luck
caypianan@yahoo.com
May 11, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
After i turn on tv- it turns off right away by itself
That board has the Sylvania part number 1EDM10583 and the price is about right. It might also need some adjustments after installation. Sylvania has no circuit diagram for that board. The TV was assembled by Panasonic and also was used in a Magnavox model. Panasonic may have had the power board designed and made for them by someone else. A technician would have to have some very good luck to repair a board like that without a schematic. Sometimes board rebuilders like PTS have the capability of repairing a board like that. You just have to ask them.
Oct 26, 2008 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Power Supply
No. They are entirely different. Panasonic was the supplier of the 6842PE and Funai was the supplier of the 6842PEM.
Oct 18, 2008 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Switches off
You have a power supply problem ,most likly the main board will have to be replaced, My best advice is to call out an authorized Sylvania dealer because if you make a mistake on what board is bad, they will not take it back. Play it safe. Good Luck
Mar 23, 2007 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
