Hitachi 53UWX10B 53 in. Rear Projection Television
Problem for Hitachi 53UWX10B 53 in. Rear Projection Television
Hitachi 53UWX10B "double vision"
By Grant - usenet poster
The customer described this symptom as above adding that the center of
the screen looks fairly ok but the top and bottom is mostly affected.
if I had to guess I would say that it sounds like a dynamic convergence
problem but I've been burned on trying to do these in home convergence
repairs before so I'm not jumping into this one without (hopefully)
some help. I asked him if the convergence screen comes up and works at
all and he says that when he selects "magic focus" he gets a 3. Does
any of this make any sense? I would like to start doing some more in
home service on large screens as the smaller set work is drying up but
I'm not familiar with this set or these symptoms at all. Does this
sound like anything familiar on this set and fixable in the home?
Thanks very much for any assistance. Lenny Stein, Barlen Electronics
Same Problem
Apr 30, 2009
-   The customer described this symptom as above adding that the center of
Thanks very much for any assistance. Lenny Stein, Barlen Electronics-   mineli
Nov 10, 2008
-   I have almost the same problem, it just happened yesterday. i was watching tv then left for a few hours then came back and noticed that the screen was blurry. after further inspection it seemed like the red color had shifted by varying lengths over different areas of the screen. i activated the magic focus and it sailed through the green and blue and got to the red screen and three little bars show up and it just stays like that for about 30 seconds like it is trying to fix something then the screen goes black and a green number 4 shows up in the lower right hand corner. any suggestions as to what happened and how to fix it would really be a tremendous help
thanks
allan-   apassey
Best Solution
posted on Aug 11, 2005
Very Helpful)
Mini Me
Rank: Apprentice
Rating: 0%, 0 votes
The "3" is an error code from the aborted magic focus attempt.
You likely need to replace the STKs, and carefully check for burned low
value resistors right off the STKs as Art suggested.  Most of the time
the resistors are OK, but if they are smoked, they need to be exact in
value.
John
Was this helpful?
Yes
No
Solution #2
posted on Apr 24, 2009
Not Rated)
Ecollier2012
Rank: Guru  Hitachi Televisions & Video  Expert
Rating: 93%, 681 votes
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Was this helpful?
Yes
No
Solution #3
Not Rated)
kioner
Rank: Apprentice
Rating: 0%, 0 votes
Convergence output ICs, maybe a couple of low value resistors, possible a
DCU with complete setup requiring an overlay for proper setup. Hard to say
with the lack of diagnostics you have posted.
Was this helpful?
Yes
No
Popular Solutions for Hitachi 53UWX10B 53 in. Rear
Questions and Unsolved Problems for Hitachi 53UWX10B 53 in. Rear
Do you recommend Hitachi 53UWX10B 53 in. Rear Projection Television?
Answer
Answer
The blue is spread out & will not focus
Answer
it has a ghost image with lots of green what could it be?
Answer
color going bad on hitachi projection tv
Answer
a blue streak / like a swoosh going across the top part of the screen and a small blue line across... (More)
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(704) 315-5981
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
