Zanussi turbo dry 1050 goes through cycles but will not spin or drain so is full of water what can i do
  • poormansfoot Nov 26, 2008
    I also have this problem on this machine - I've checked the filter - and yes it needed cleaning - but no change. The machine starts a spin - so it can do that bit - but it just then slows down and ticks over. Any help much appreciated
I find the wires from my wife's bra get stuck in the filter. You need a bit of brute force (not too much - don't break the filter) and dextrous fingers in the filter to get them out. When the filter is out just feel in the hole it's come out of to make sure that there's nothing else in there to get caught up again.
Posted on Oct 14, 2008
    President:
  • 1,462 Answers
Check filter (bottom rhs side. if still no joy, then maybe foreign object in pump
Posted on Jul 13, 2008
Hi my Zanussi ZWG 1120M washing machine has stopped spinning, no error code is displayed, what could this be?
First check if the water remaining in the drum?
If it is, then the fault is in the drain phase (drain pump,filter...etc.) before the spining cycle.
Otherwise, faulty is motor, belt, electronic....etc.
By the way, model is unknown to me.
Dado
Jan 11, 2015 | Zanussi Washing Machines
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Zanussi Washing Machines
Zanussi washer dryer showing e20 error message in dryig cycle
Hi
This means that the filter is clogged. Unscrew the filter it'll be full of lint. E20 also means drain problem. If it actually goes through the Spin cycle then there is most likely some water still not drained out at the time of the tumble dry. Check the drain and the hose to make sure it isn't clogged.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jan 03, 2011 | Zanussi Washing Machines
Drum wont turn on the spin cycle, it's ok on a
if its pumped all water out and wont spin sound like your motor brushes are worn.
Oct 16, 2009 | Zanussi ZWF1230W Front Load Washer
Washing cycles
if you put machine on a delicates or wool wash, it will stop still full of water giving you the choice to only drain or drain and spin
Sep 10, 2008 | Zanussi ZWF1440 Front Load Washer
My Zanussi F1245W Wont Drain or Spin
Check the drainpump. It could be burned og blocked.
Jan 20, 2008 | Zanussi F1245W Front Load Washer
Zanussi turbo dry 1200
Try cleaning out the pump, and main hose to sump. If problem persists replace pump.
Slim Jim
Nov 12, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi turbodry 1050
this may sound silly but check the waste outlet pump electrically, some models are wired up so if the pump fails the water will not enter the machine, this works on the theory that if it fills up it can not empty also check the solenoids for open circuit electrically, double check the water supply to the machine, it may have been fine but you could have kinked the pipe placing the machine back where it should go?
Oct 04, 2007 | Washing Machines
Washer dryer is no longer drying
two things to check take rear half of cabinet off and check the dryer duct (lhs from front) is not blocked. this is very common check water is being taken in during dry - the water is used to condense steam from the drying clothes. easiest way to check this is to see that some water is being drained during the drying cycle. i assume that drain is operating ok
Jun 03, 2007 | Zanussi ZWD1270 Front Load Washer / Dryer
Zanussi jetsystem Turbodry 1200
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
