Televison & Video Logo
Posted on Jul 13, 2008
When I tun the TV on the power comes there is no picture and the power light blinks twice about every 5 seconds. I have unplugged the tv then turned it back on. The power light comes on for about 3 seconds then starts blinking agian
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 13, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
124
Points
Same thing happened to me u need to get a new flyback
1helpful
5helpful
When I turn the tv on the power light goes green for a couple of seconds then it shuts off and the picture never comes up.
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
4helpful
When I turn on the TV the blue indicator light comes on but there is no display, then the blue light starts blinking.
The following steps should be able to correct the problem:
1) Unplug the TV or remove AC power from the TV
2) Count to ten and then plug in the TV
3) Locate the [Menu], [VOL-] and [Power] button on the TV’s side panel
4) Using the buttons on the TV’s Side Panel, press and hold both the [Menu] and [VOL-] buttons.
5) While holding those buttons, press and release the [Power] button one time and count to 3 before releasing the [Menu] and [VOL-] buttons.
6) The TV’s lower left Blue Power LED will come ON.
7) Wait 30 seconds. Confirm that the blue LED on the Lower Left of the TV (not the iPod dock for iPod models) has remained ON during this time.
8) Press the [Mute] button on the TV remote twice
9) Unplug the TV or remove AC power
10) Count to ten and plug the TV in
11) The TV power should automatically come ON and the blue power LED with be ON
12) Wait 40 seconds and the TV picture should appear
13) You can now continue using your TV.
14) If the picture does not appear, power on the TV manually:
· If the LED begins flashing, unplug and power ON a second time.
· If the LED begins flashing again, power ON the TV without unplugging
If the LED begins flashing again, contact us directly by phone to obtain a local authorized service center for you.
If the TV does power on, please reply back with the software version number for us to research this issue. Please follow these steps to obtain the software version number:
1) Press the [Menu] button on the remote control.
2) Using the arrow keys in the center of the remote, scroll over to the "settings" menu and select the [OK] button on the remote
3) Scroll down to "system info" and select [OK] button on the remote
7helpful
3answers
Tv turns on then off after a few seconds. No picture or sound in these few seconds.
Try this and let me know what you find:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
if this has helped you rate this solution as I do this here for free.
SD TECH
3helpful
I have a Mitsubishi big screen tv model #WS-65857 and the picture went out as though the tv was turned off and when you turn it back the green light comes one for about 5 seconds the goes of there is no...
if your set does not have a device button press Menu and Input together for 5 seconds and release. there will be a pause between blinks---2 blinks, a pause and two more blinks etc.
If you need help: [email protected]
I do this here for free so if this has helped you give me a vote here.
4helpful
2answers
My model is a WS-55511. I turn on the TV, the
1helpful
3helpful
4answers
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Panasonic pt53wx42f
This sounds like a main power board issue. After you unplug it, it will work? Are you planning on trying to service it or having it serviced?
Thanks,
Lee
Flashing lights on philips flat panel tv
This can be the main power supply has failed, and or there is a short on one of the processor boards.
The set will have to be brought in for service.
Jerry G.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
