Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
Have a Bosch WFMC 3200UC and gives a E04 error.
Problem is that the washer will not drain and the door is locked. The hose is not blocked but I cannot get inside to see if there are any other blocks due to the door lock.
I can hear the pump working put no water is drained?
Any suggestions?
  • jpay Aug 17, 2008
    I am having the same problem with error code E04. I am able to open the door, but it will not drain. I have cleaned the hose and there is nothing blocking it...
  • 3 Answers
In order to unlock the door on this machine you must first turn the cycle knob to a cycle that was different than the one you were on. The machine should then reset and the door should unlock.
Posted on Jul 17, 2008
What is error code e04 bosch front loader washer
The "E04" error code on your Bosch washer refers to a drainage problem as you may or may not already know. ( it can mean door lock error, but that is usually a by-product of it not draining )
What you may have is either a partially clogged pump, or a faulty pump...the later being the least likely
Nov 22, 2016 | Bosch Washing Machines
What is error code E04 on hoover washer
E:04" on the washing machine. Check to ensure there is no water in the tub. This is a common error often associated with too many suds blocking the pump. It is caused by using the wrong laundry detergent which is not designed for high-efficiency washers. You can adjust your use of detergent and reset the machine to eliminate the error code.
Read more : http://www.ehow.com/how_10038363_reset-bosch-washing-machine-error-e04.html How to Reset Bosch Washing Machine With Error 04 eHow
Jun 21, 2015 | Hoover Washing Machines
I have a e 04 code when it is going into the rinse cycle
Hello, welcome to FixYa.
The "E04" error code on your WFMC series Bosch washer refers to a drainage problem as you may or may not already know. ( it can mean door lock error, but that is usually a by-product of it not draining thus the error appears during the rinse/drain )
What you may have is either a partially clogged pump, debris blocking a hose or a faulty pump...the later being the least likely.
You haven`t mentioned if you`ve actually visually checked the pump...it is likely just that, a blocked pump.
Anyway, here`s the most likely way to remedy a E04 code.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
  1. Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, hopefully you won't get wet. ( maybe you`re lucky enough to be close to a floor drain )
  2. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)
3. Find a drill bit or small screwdriver that fits in the hole in the round door.
4. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful or wear chain-mail gloves).
5. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. (you should also see a green ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan. This will deal with the door lock issue but it likely isn`t unlocking due to the water in the tub )
**There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out.**
6. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.
7. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
8. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, or a lock, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this indeed solves your problem, please rate the solution I provided accordingly. Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
Oct 15, 2011 | Bosch WFMC 3200 Front Load Washer
BOSCH WFMC3200 Washer - Receiving E04 error and manual indicates clearing drain hose and pipe. How do I remove the cover on lower front of machine?
there is small hole in the cover you need to push a small screwdriver or ice pick works in the hole and then turn clockwise till it comes off.
But there will be some water come out so if you have a wet dry shop vac then use it on the end of the drain hose to remove most of the water then keep it handy when you take the plug out there will still be some water come out and you should be able to clena out the trap area
Nov 30, 2010 | Bosch WFMC 3200 Front Load Washer
Bosch WFMC 3200UC can't rotate the drum
that test indicates a faulty speed sensor or wiring harness.
Jan 23, 2010 | Bosch WFMC 3200 Front Load Washer
We are getting error message E04 on our Bosch front loading machine and it won't drain and it makes a grinding sound.
We removed the round panel in the front and there was a knee hi stocking stuck in the filter - great advice - it's fixed and working perfectly.
Jan 03, 2010 | Bosch WFMC 2100 Front Load Washer
Flashing E:04
Further on the solution provided on Oct. 28th.
The circular cover is on the front, below the door on the 3200UC. Use an unfolded large paper clip or in my case a large safety pin and push in where there is a small hole. Rotate the cover slightly and it opens. Once you get that open, there is a valve to unscrew. Be sure to have towels or sponges around as this will drain what ever water is left in the drum. Unscrew the cover only a little until water starts to leak out. Once it's drained, remove the valve cover completely. There is then another white plastic piece that you can gently pry out with a flat head screw driver. Once that's out, you'll be at the main drain. In my case there was an infant sock blocking the drain. I removed that and the machine works like a charm again.
Hope the details help a bit. Thanks for the original solution!
Oct 07, 2008 | Bosch WFMC 3200 Front Load Washer
I have a bosch wfmc 2100 washer that doesn't drain
Have a look on the Bosch web site, they offer solutions to some problems, if not contact them via email
Jan 01, 2008 | Bosch WFMC 2100 Front Load Washer
E04
Perhaps try opening the round panel on the front of the machine at the bottom and cleaning that hose...good luck because it might be messy.
Nov 19, 2006 | Bosch WFMC 2100 Front Load Washer
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
670 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
