Wireless extender hi. i need to config my 'Sitecom Wireless Range extender wl-130 to my bebox thomson tg585 v7. cant seem to understand how the 2 can connect. please help?
OK.
It's pretty easy:
1) turn on both devices
2) connect to sitecom device.
- you may have to manually set your IP address. (from network resources control panel, TCP/IP tab. Check the istructions, cause you have to choose an address in the same subnet of the sitecom range extender. I mean, the first three numbers must be the same, and the last number of the address must be different, between 3 and 255).
- now you can type the sitecom address into the address bar of your browser (allow pop ups from that address!). The defaut user name is admin, as well the default password.
3) Ok, now you're connected and you just have to set this way in the basic settings:
working mode: universal repeater
now click on site survey and remember the ssid of your main network, and the channel number.
channel: type the channel number of your network (IT MAY CHANGE WHEN YOU TURN OFF\ON THE ROUTER!! so you'll have to change it maybe every day..... **** sitecom device, I HATE IT)
ssid: the ssid of your main network.
4) click apply.
Of course if your WLAN is protected you must set the rigth password and encription algorithm...
Now it should work.. but remember, everyday you will have to change the channel, and sometimes ou will have to reset it, from he toolbo tab.
IT,S BETTER NOT TO BUY THIS DEVICE, cause even the latest firmware is not working properly.
Posted on Sep 18, 2008
Cant enable wireless on my Bebox
The full set of user guide are here http://www.thomsonbroadbandpartner.com/dsl-modems-gateways/products/product-detail.php?id=161
browse to http://dsldevice.lan or to the IP address of your Thomson Gateway (by default: 192.168.1.254) and click Thomson Gateway on the menu on the left-hand side.
Another option is to reset your Thomson Gateway and reconfigure it all over again. have a look at chapter 7 of this manual http://www.thomsonbroadbandpartner.com/getfile.php?id=5349
Mar 23, 2010 | Dell TrueMobile 1184 Wireless Broadband...
Thomson tg 585 wireless multi user adsl2 GATEWAY
Hi, Did you manage to solve this. I have a similar problem. My thought would be to add belkinf5d7132 as range extender, but not sure if this works with thomson tg585. Regards
Dec 10, 2009 | Belkin (F5D7132) 802.11b/g Wireless Access...
Non connectivity with thomson tg585 v7 modem with bsnl broadband.
what is bsnl broadband if you have thomson to acsess the setup and all it freater just type speedtouch.lan in your browser this may help you
i think
Jul 02, 2009 | Thomson RCA DCM245R Modem
Can't conect to modem
I have just set up a broadband connection for some neighbours using the Thomson router and had similar problems.
Leave the computer on, power down the router, leave it for a few seconds and power it up again. It worked for me.
But it seems that we have this problem every time i,e if the router is on and you switch on the computer it won't connect, but if the computer is on and you switch on the router everything works as it should. I haven't got to the bottom of this yet.
Feb 18, 2009 | ASUS WL-138G 802.11g/b (wl138g) Wireless...
Problems configuring WL-130 Wireless Extender
http://192.168.0.1
then type user name:admin
password is:admin or blank
then enable DHCP.then u can get ip automatically.
Nov 12, 2008 | Computers & Internet
Dwl-2100ap set up propblem
There's quite a bit to know about extending / repeating WIFI signals.
Read about extending a WIFI signal with a Sitecom WL-130 repeater here.
Sep 05, 2008 | D-Link AirPlus G Wireless Range Extender...
Problem with sitecom wl-130 connection
I think I have the solution: you have to click on the basic settings tab, then n "site survey" button, then (optional) on "refresh" button.
Now you will get the information about your network, and you just have to check the channel number of the signal from your main router. then you have to set that channel in the "channel" button of the basic settings tab. You also have to choose Universal repeater as working mode of the sitecom device, instead of Access Point.
Hope it helps.
By the way, all these settings should be automatic in such a device.... But this sitecom range extender is ****.
I suggest everybody is reading: DON,T BUY THIS ITEM!!!! Spend 10 bucks more and get a working one!!!
Jun 01, 2008 | Computers & Internet
Compatibility with Sitecom wl 031
This 10dBi omni directional antenna enables you to very easily extend the range of your wireless network. By linking the Omni Antenna to your wireless router, you gain the benefits of an optimum wireless signal while minimising the number of ‘dead spots’ (points in your home where the signal is either weak or lost).
However it does not fit the following types of routers,modems and accespoints:
WL-143
WL-122v2
WL-114/WL-517
WL-114v2
WL-108/WL109
WL-111
WL-106
WL-025
WL-018v2
These antenne's will also fit other brands of wireless products that use an SMA connector
Jan 29, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
1,000 people viewed this question
David Payne
David Payne
