My CD's will not play on my Denon 2910 anymore. The DVD's have no problem and play fine (sounds and picture). However, when I enter a CD, the display indicates " loading" and then jumps to 00H00M00S. To the left of the time indiactor the word "progressive" is lit up in red.
I have no idea what th eproblem could be. Can anyone help?
I have the same problem with my Denon DVD-2900. The unit stops loading/reading next cd that i put immediately after finishing 1 cd. I have to repeatedly re-load the disc or switch off the unit for a while to make it play a disc again.
No problem with dvd and sacd discs though.
Same problem
There has been a number of reports of similar issues with Denon models that utilizes the 'PureProgressive technology'. Some of the issues and tried corrective measures are - 1. It would appear that in certain occasion, performing a "region free hack" disables the 'PureProgressive technology' and one solution tried is to set the unit to NTSC and not multi or PAL; 2. disable/turn-off digital output; 3. some has reported significant improvement when a firmware upgrade was performed; 4. use DVI instead of of other outputs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
On a Denon DVD 2900 I cannot advance the DVD from the first title to the next. I do not have a...
(More)(More)
On a Denon DVD 2900 I cannot advance the DVD from the first title to the next. I do not have a remote and can't seem to find anything on the unit itself to do this. Everytime I hit next it just goes back to the first episode. Any ideas?
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
Denon was working fine with SACD and DVD-A had balance of front to back set perfectly. I switched...
(More)(More)
Denon was working fine with SACD and DVD-A had balance of front to back set perfectly. I switched machine on a couple of weeks ago, suddenly the rear speakers are rearly loud - much more so than front. The surround processor and amps are fine as it only happens when Denon is decoding - ie. I use the AV processor for films. The 5.1 bypass being used for hi res audio only. Sounds like a software fault in machine, can I reset it somehow. Obviously I have played with the volume settings in the Denon menu but they don't make enough difference to the volume, YES it is THAT bad!
Posted. Thank You!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
