Question about Lexmark X4270 All-In-One InkJet Printer
My printer got jame form paper i remover the paper, now tha printer as an error #1200 see user guide.
  • 3,940 Answers
The 1200 error is caused by a cartridge carrier stall. This can happen if:
  • The print cartridges are not snapped in correctly.
  • The encoder strip is out of place.
  • A foreign object is blocking the cartridge carrier's path.
  • http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&emeaframe=&docid=ENUS23485
    Please rate this post. =)
    Posted on Jul 14, 2008
    I have HP designjet t 1200 series printer ..Today while feeding the paper inthe roller it says remove the roller and feed the paper inthe roller 1 .what is the problem????/
    For Tech Gus only:Error message: Remove paper from sheet path:
    Resong: Dut dust formed on paper sensing IR sensor.. Remidy.. check the snap shots to clean paper sensor, contains how to remove, clean.. Remove right door then start follow the snap shots...11_19_2011_12_44_55_pm.jpg11_19_2011_12_45_17_pm.jpg11_19_2011_12_45_56_pm.jpg11_19_2011_12_46_48_pm.jpg11_19_2011_12_47_35_pm.jpg
    Fix all carefully.. Best of luck..
    Jul 12, 2011 | HP Designjet T1100ps Printer
    Paper Jame when i start printer after 10 to 12 houres and hang after three or four time restart printer then print the paper
    This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
    Nov 10, 2010 | HP LaserJet 1100 Printer
    It is saying paper james in the printer, open the scanner unit and remove paper, however there is no paper, have turned off the machine and still comes up with the same problem
    Oct 25, 2010 | Office Equipment & Supplies
    My printer is barely a year old and the paper gets jamed once the printer pulls the paper in.
    Oct 25, 2010 | Canon PIXMA MX310 All-In-One Printer
    Paper Jam HP LaserJet 1300
    I hope this will be of Help for the HP LaserJet 1300 Paper Jam Trouble Shooting:
    1. See the product user guide for information about clearing jams from the printer.
    2. Make sure that the paper guides are adjusted properly. Slide the guides against the sides of the stack in the main input tray or the priority input tray to center the page. Make sure that the guides are not adjusted too tightly.
    3. The media input tray might be too full. Remove some of the sheets.
    4. Make sure that the media being used meets specifications. Click here to refer to "Media specifications" for more information .
    5. Make sure that the media being used is not wrinkled, folded, or damaged.
    6. Make sure that the printer is clean. See the product user guide for information about cleaning the printer.
    7. If printing to the straight-through output path, close and open the door again to make sure that the green release levers are closed.
    8. The paper might not have been removed from the main input tray before the tray was refilled. Always remove paper form the main input tray before refilling it.
    9. Output capacity might have been exceeded in the paper output bin. Do not allow more than 125 sheets of 20-lb (75 g/m2) bond weight paper to fill the paper output bin (less for heavier paper).
    10. The pickup roller or printer separation pad might be dirty or damaged. Clean or replace the part. (See the product user guide for information about cleaning and replacing the pickup roller and printer separation pad.)
    Apr 03, 2010 | HP LaserJet 1300 Printer
    Lexmark X4270 shows error message #1200 and to consult User Guide. We do not have one and do not know what error #1200 is.
    Hardware Error: 1200
    The All-In-One is stalled.
    1. Press Power to turn off your all-in one.
    2. Unplug your all-in-one fro the wall outlet.
    3 Check for paper jams.
    4 Plug in your all-in-one
    Cartridge Error: 1200
    The cartridge carrier is jammed.
    1. Turn off your all-in-one
    2. Unplug the all-in-one form the wall outlet.
    3. Open the control panel.
    4 Open the cartridge access door
    5. Make sure the cartridges are snapped in place in the carrier.
    6. Check for objects obstructing the carrier.
    7. Plug in your all-on-one
    8. Press power to turn your all-in-one back on.
    That's all the information I could find.
    Jan 15, 2010 | Lexmark X4270 All-In-One InkJet Printer
    What is error #1200? I don't have my User Guide
    Causes of Error 1200 Error 1200 is a critical system problem that is commonly caused by an unstable system registry or corrupt system files that are required to run Windows smoothly. This must be fixed immediately to prevent further problems to your data, applications and hardware
    Dec 13, 2009 | Lexmark X4270 All-In-One InkJet Printer
    Error 1200 what is this. I cannot locate my user's guide
    Hello Sir, The error on this printer means that the AIO which is All-In-One is stalling or completely stalled. The repair procedure is given below. But you can reply me back clarifying that is it showing Cartridge error 1200 or Hardware error 1200. :--------- THE PROCEDURE:--------------------------
    • Turn the Printer completely off to turn off AIO.
    • Then check for any Paper inside.
    • After confirming that there is none then Un-plug the AIO from the Outlet located in the wall.
    • After 10 Min, replug and check function.
    Also the problem can be on the Catridge ( Most Commonly ). In this case you need to check the Catridge socket for any obstruction and also check that the Cartridges are not stuck or misplaced.
    Reply me for any further assistance on the Issue.
    If the printer is only showing that error 1200 then take care of both the AIO and cartridges reset. Both have to be done.
    Thank you Sir, Have a nice day.
    Oct 20, 2009 | Lexmark X4270 All-In-One InkJet Printer
    PAPER JAM
    Look for a "jam door" at the rear of your printer (if so equipped).
    You will need : 1 can of "compressed air", 1 container of ether rubbing alcohol or some form of Goo-Gone.
    1. In short blasts (NOT LONG ONES) blow through the paper path. Open any paper jam access trays before doing this so the bits escape.
    2. Using a SMALL amount of Goo-Gone and either a Q-Tip or small dust free cloth, clean all the rubber rollers on the bars. Cheap paper leaves a fine dust and after time will make the wheels very slick.
    Doing this every other month can save you from jams and is just a good maintenance plan for your printer.
    Also don't use 'cheap paper'.
    Good luck! :)
    Dec 02, 2008 | HP LaserJet 1300 Printer
    Lexmark fax machine series x4270 has an error code saying #1200
    Please click on this link :
    http://support.lexmark.com/perl/support/support.cgi
    and then click on support ,once the page is opened please center X4270 in
    Search by Model ,after that choose Lexmark X4270 ,after seconds a page will open and then in
    Search the KnowledgeBasePut this number and follow the steps given:
    ENUS23485
    good luck...
    Oct 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
    Lexmark X4270 All-In-One InkJet Printer Logo
    59 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Roopesh S
    Roopesh S
    Sanath Kumar V
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
