Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Dishwasher does not want to drain
I am renting at a place with an old built in Kenmore dishwasher (I am not sure which model, it only says "Kenmore Ultra wash" on the front) and the water does not want to drain. I have removed the water distributor at the bottom and have found some paper and a fork around the edges of the circular drain, which I removed. However, the dishwasher still does not want to drain. I wanted to open it further, but I need a special tool to remove the screws and I thought I will ask advice first.
I would appreciate if you can help
  • 1 more comment
  • hopper111 Jul 27, 2008
    My Kenmore - model 665 - will not drain either. It's about 8 yearws old. I've never had a problem with it before. I cleaned some bits of paper and two plastic spoons out of the drain area, there doesn't seem to be anything else in there but it still won't drain. Help!
  • Anonymous Aug 02, 2008
    water will not drain. is my pump gone
  • smavella Nov 08, 2008
    ultra wash dishwasher will not drain model 16629
Make sure that the draining-hose is clean .... Try to put the draining-hose downwards .... it is possible that the pomp can not push the water high enough .... if the hose runs downwards ... gravity will help !
Posted on Aug 04, 2008
Kenmore Ultra dishwasher model 665 wont drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Sep 11, 2011 | Kenmore 24 in. 16032 Built-in Dishwasher
Where can I find the model # on my Kenmore Quit Guard?
Hi
To locate the model # for your dishwasher, you'll need to look at the following places---
You'll see a model tag number, on that you would see the model number--
Hope this helps....
Daniel
Aug 21, 2010 | Kenmore 16602 / 16604 / 16609 Built-in...
Wont drain
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 06, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
My dishwasher won't drain. It is a Kenmore and about 8 yrs old
There is a panel tht separetes the top from the bottom you need to unscrew it. Place a pan under it after you see a little spout/drain hanging down that is probably fill with gunt what ever water that is in it will drain out clean it out , replace it after you've let the water run out. once you've screw it back see if your dishwasher is draining correctly.
Nov 17, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
good thinking,first it would help if i knew the model # if you open the door it should be right there on the left side.has it ever drained for you? is there a new garbage disposer installed in the sink? the special screw is a torx.
Nov 08, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 665.16705891 dishwasher
First make sure it will run by hitting "cancel' or turning the timer to drain cycle.What is the Model& Serial number???I'll be happy to get this solved for you. :)
May 17, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
GE Nautilus Dishwasher No water when i turn it on
You need to prime the dishwasher by placing two large cups of water into the bottom.
Mar 19, 2008 | GE Nautilus 24" Built-in Dishwasher
Kenmore built in dishwasher model # 665.16831792
timer is ordering draining. or solenoid is on and it drains non stop.
Oct 31, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
145 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
