Question about Nespresso C100B Essenza Single-Serve Automatic Espresso Machine, Black
Does not stop making coffee
When I press the button to make coffee the coffee keeps coming and the machine never stops.
The machine has a reset capability to set the amount of coffee. Just push and hold the button for as long as you want coffee. Then let go of the button and it's reset.
Posted on Jul 14, 2008
Espresso (small coffee) doesn't work anymore
you have to change the amount of the water on the small coffe button. Press and hold it while is making coffee .When you want to stop -just take off your finger from button.
Aug 22, 2014 | Gaggia Titanium Espresso Machine
Brand new Nespresso Inissia M105 won't heat the water
Just a brief addition, I don't have the Magimix model, but I have a similar one. It loses it's programmed settings if it is unplugged or switched off at the wall, but if you leave it plugged in but turn it off with the switch at the back it keeps the settings you have put in. It draws virtually no power when it's switched off with the switch on the machine, (I checked it with a power meter).
Just thought I'd share that with you.
May 15, 2014 | Nespresso Coffee Makers & Espresso...
At first my Miele CM5000 worked perfectly. When I pressed the espresso button, a perfect espresso would come out- the machine dispensed the correct amount of liquid then stopped automatically. Now, the...
If the espresso coffee outputs too much water and doesn't stop, there is an easy fix. The quantity adjustment for the machine is off. After looking through the user manual, I found out that you could press and hold the espresso button, and then follow the on-screen instructions where you can specify the quantity poured.
Aug 03, 2013 | Miele Cm 5000
Hello The lights on the front of the machine wont stop flashing so I can't press the cup symbols to make coffee. The hot water is coming out though through the steamer spout. Thanks!
Circuit Priming
When the machine operates for the first time and when
all the water has been dispensed, the machine circuit
needs priming. In this case, the 4 buttons of the control
panel will flash at the same time.
• Press the ON/OFF button . The 4 buttons will
flash.
• Place a container under the cappuccinatore.
• Open the "hot water/steam" knob by turning
it anticlockwise.
• Press the hot water button.
• Wait for water dispensing to stop.
• Close the "hot water/steam" knob by turning it
clockwise. Remove the container.
When the first priming ends, the warming up
starts. Before brewing coffee, water and steam,
please wait for lights 15 and 16 to be permanently on.
The machine is now ready to brew coffee and dispense
steam. Please see related sections for operating details.
Note: if priming is not completed, the 4 buttons
will keep on fl ashing. The machine cannot be
used.
Jan 14, 2011 | Saeco Nina Bar Espresso Machine
How do you calibrate the dosing for a Cimbali M29 Select?
Keep press smoothly the ceter button stop for more than 10 sec. You will hear a sound and lights bliping.
now fill the filter with coffee and press the button you want to program and keep it press untill you will have the required dose in then cup.
Now the dose is set.
you can program all other buttons in the same way.
after you finish you can press once the stop buttong again. The machine is been programed and ready to be used.
You can reprogram any button you want again following the same prosedure.
Good luck.
Rememebr to vote for this answer
Mar 23, 2010 | Espresso RMI La Cimbali Espresso Machine
How do you program dose volume?
Good luck.
Rememebr to vote for this answer.
Mar 20, 2010 | Espresso RMI La Cimbali Espresso Machine
No coffee is coming out of the machine...
in our machine we wanted a stronger coffee so we adjusted the auto grinder (where the coffee beans are housed) to the finest setting thinking the finer the grind the stronger the coffee...after doing this the machine wouldnot make coffee...we sent it away while still under warranty and the tech said that the grind selection was too low so they just turned the grinder back up a notch and it worked fine ....dont know if this will help but it's worth a try!
Mar 26, 2009 | Krups Orchestro Dialog FNF2 Espresso...
Self-clean button keeps coming on
Unplug the coffee maker for 1 hour or longer - it wil lreset the machine, and turn off that self-clean light.
Feb 07, 2009 | Cuisinart DGB-600 Coffee Maker
Stuck Button
You need to replace your coffee button. If you need to order the part please contact:
Authorized Gaggia Service Center
Cerini Coffee Services
New York, USA
www.CeriniCoffee.com
support@cerinicoffee.com
Aug 01, 2008 | Gaggia Baby Espresso Machine
Clock just keeps going
That button can stick due to coffee having dripped on it. Work a little water in there and press the button several times until the coffee dissolves, the button comes free and the time stops changing.
Mar 06, 2008 | Black & Decker SpaceMaker ODC325 Coffee...
Nespresso C100B Essenza Single-Serve Automatic Espresso Machine, Black Logo
1,385 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
