My Hitachi projection TV needs convergence amps. what are convergence amps?
  • 8,617 Answers
The convergence amps are usually located on the extreme right side of the chassis looking in from the rear of the set. Located on a large heat sink. If you respond to this post with your correct model number I will post the correct ICs for your model, and you will need to replace the six convergence resistors as well.
Posted on Jul 13, 2008
I have a60 inch hitachi projection tv. I tried to fix the screen alignment using the grid but the blue line doesnt move to line up on the grid. The green and red work fine. So theres a blue ghostly glow...
you will need convergence work done & for Hitachi I recommend a professional as the convergence will have to be reset for normal & HD pictures. See if you can get a quote from a local servicer.Be sure you are sitting down.
I really think your money would be better spent on a 21st century LED or LCD TV.
Jul 22, 2014 | Televison & Video
How to fix a hitachi rear progection tv that has problem with green
If the convergence is so far out that you cannot adjust with your customer access menu then You will probably need the convergence ICs replaced & possibly a fuse or resistor or 2. Then a complete convergence will be necessary & I HIGHLY recommend having a professional technician perform this task.
May 23, 2014 | Hitachi Televison & Video
Hi, I have a Hitachi 53swx10b projection tv. the colors are bleeding and sort of glowing. any idea what this tv needs? thx, John
Ur tv convergence are dead.U know how to solders?Must replaced 2 STK convergence ICS,and some or all the resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost $300-350 for parts and labors.
Apr 03, 2010 | Hitachi 53SWX10B 53" Rear Projection...
Hitachi 53swx01w HD rear projection tv was fine until i ran the magic focus. now i have blue & yellow ghosts.
Ur convergence is dead.U must know how to solders?Must replaced 2 STK convergence ICS and some or all the resistors.Tries Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost U $300 for parts and labors.
Mar 17, 2010 | Hitachi 53SWX01W 53" Rear Projection...
How do I aling colors: the red and blue colors are not align making the tv look distorted.
On my Hitachi there's a convergence button on the front panel. Press that button which will give you red & blue lines. You have to use your remote to converge (align) those lines to correct the picture. If the lines won't converge I've been told it could be a bad convergence IC & tech is needed to fix...could be approx $300 to fix.
Jan 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
How do you replace a Convergence Amp IC's on projection Hitachi tv?
The DP14G convergence repair kit from www.tvrepairworld.com is the correct kit for your model and the kit contains the parts and the CD with instructions.
Nov 03, 2009 | Hitachi 53UWX10B 53" Rear Projection...
RePost:Hitachi 51F510 W/ No Power HELP
The convergences amps are found either on the neck of the CRTs, or a seperate board directly connected to that area via cabling, depending on version of chassis...accordianman
Feb 15, 2008 | Hitachi 51F510 51" Rear Projection...
Hitachi 50ux22b has dark screen and general CQ adjustment issues
is the convergence off?
bad convergence amp ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 05, 2008 | Hitachi 50UX57B 50" Rear Projection...
Ultrascan hitachi 43" hd tv
Marcus,
What you're describing is convergence and the amps need to be replaced... IK04 and Ik05 are two STK392-110 and Hitachi suggests replacing them with the STK392-150's for greater reliability..
If you're not too capable in electronics this is one to leave for the professionals. But at least you can call around and ask what each shop charges for replacing the convergence amps in this unit...
Hope this helps.
Bill
Nov 14, 2007 | Hitachi 43GX01B 43" Rear Projection...
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
