Question about Saeco Magic De Luxe Espresso Machine
Water in bean dispenser/grinder
Hi Mirran,
You seem to know a lot about this! I read your posting but am uncertain of how to take off the bean hopper. Do I have to remove the screw in the middle of the grinder to take it off?
  • mtdd Jul 14, 2008
    I've removed the screws, as well as the "rubber" that covers the grinder...but can't seem to get any further?
    I'm not sure how to remove the plastic or turn the ring anticlockwise. I feel like I could break it? How do I ger the plastic adjustment?
    So far this has been very helpful - thanks so much!
Posted on Jul 13, 2008
  • 515 Answers
If you look at the bean hopper you will see two screw, loosen this and take off the bean hopper. Now you will see the grinder, you have to take of the adjustment on the side, that plastic on the grinder.
Now you can turn the ring anticlockwise, and take out the middle of the grinder.
Let me know if you wondering about anything
  • Mirko Blas
    Mirko Blas Jul 13, 2008
    One more thing, don´t take off the screw in the middle off the grinder.
  • Mirko Blas
    Mirko Blas Jul 14, 2008
    If you look at the plastic adjustment, you will see two sliding hole. Put down a screw driver in the hole and prize little, make sure the adjustment is on "5" when you take it off.
    If you now take on the outside of the plastic ring and turn it anticlockwise, turn it so you can see the notch, now you can lift up the ring from the grinder.
    When you put it on again you will turn the ring clockwise to the end and then turn it anticlockwise 14 step to get it in center.
Grinder spins. Hopper is full of beans. Why is no ground coffee dispensed?
You will probably find that the grinder is bunged up with grounds. This can happen if there is a bit too much steam inside the housings. The grounds bind together and will not drop with gravity. Pull the grinder apart, clean it out then run it with the top housing off and see if you can observe any leaks/steam. There will be some steam, you are looking for excessive steam.
Sep 13, 2015 | Miele CM 5200 Espresso Machine Black
I owe the miele CVA4075 BUT my whole bean grinder is not grinding the bean and only water gets dispensed, anyone have a solution?
Make sure the hopper is working correctly to see if there are any blockages, then check under the hopper to the opening where the beans go to the grinder. My guess is that there are a few beans and chipped portions of beans which are clogged under there.
Jun 28, 2011 | Miele Coffee Makers & Espresso Machines
My Jura Ena gives a 'fill beans' message even though the hopper is full and it won't grind the beans even though it seems to be operating. Help.
Mine just started doing the same thing. I've always only used plain espresso beans. Only thing is I may have overfilled the hopper and packed the beans down a bit. How can I make it start grinding again?
Sep 08, 2010 | Jura Capresso Jura Ena 3 Espresso Machine ...
Machine has major problem with grinding beans.
Try removing all beans from bean holder - then use a vacumn machine to remove the bits down amongst the grinder "teeth'. You may have had a small stone in your coffee and if so it may have jammed the grinder.
Once it looks clean, try making a cup of coffee without the beans in the hopper - you should be able to see and hear the grinder revolving and also hear the brew unit moving between the grinder outlet and the water inlet. If it all seems ok now, then add a small amount of beans back into the beans hopper and try making a coffee. If it still will not work, get it serviced. There's not much the average person can do inside these units other than to do more serious damage or kill themselves with an electric shock.
Nov 05, 2009 | Saeco Magic De Luxe Espresso Machine
Brand New Incanto, Grinder Doesn't Work
If you look at the adjustment knob in the bean hopper, make sure it is in the middle i think it will be "8".
Make sure you not get any damp into the grinder.
Try to make 2-3 cup of coffee.
Let me know if i can help you more
Best regards
/Mirran
Nov 08, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco Vienna grinding issue
I think so, most problem with that the grinder grind to the lamp light up is damp in the grinder or oily beans.
if you have two adjustment knob in the bean hopper then the second problems can be the micro switch in the machine that have to be replaced.
Best regards
/Mirran
Nov 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
Stuck grinder
make sure you not get any damp into the grinder. If you have damp in the grinder then it do not grind the beans.
/Mirran
Aug 30, 2008 | Saeco Incanto Classic Espresso Machine
Full of Beans
You have to mount a resistance on the power card.
/Mirran
Aug 24, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco magic de luxe grinder problem
Hi Cindy,
Make sure you not get any water in the grinder, if you get water in the grinder then it bean smeary and will not grind the beans.
You have to clean the grinder if you get any moisten in it.
/Mirran
Aug 17, 2008 | Saeco Magic De Luxe Espresso Machine
My Saeco won't grind the beans
There's moisture in the grinder & it's clogged - just dismantle the grinder & clean it, then ensure you don't splash water into the bean hopper when you fill the water tank.
Mar 29, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
133 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
eyecam
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
