Question about Brother Office Equipment & Supplies
Back cover open - Brother Office Equipment & Supplies
  • 9 more comments
  • babymoney Aug 25, 2008
    it says the back cover is open we tried turning it off
  • poolside Sep 29, 2008
    There was a paper jam in the rear that has been cleared. Message still says that the "back cover is open".
    Where is the switch that detects the cover is closed?
  • Anonymous Oct 07, 2008
    "Back Cover Open"   What back cover?
  • Anonymous Oct 10, 2008
    Back cover is closed but receiving the message 'back cover open'
  • hyphill Oct 21, 2008
    Had a paper jam, cleared it, and now the printer is INSISTING the back cover is open. It's not. What's up with that?! I really need to print stuff!
  • mtn_ayla Dec 05, 2008
    brother dcp 7020 printer: had a paper jam and cleared it. but the dumb machine keeps insisting that it has a back cover open when it's not. what's the solution???
  • Anonymous Dec 30, 2008
    my printer says back cover open
  • Anonymous Jan 11, 2009
    I have same problem. How canI solve it
  • Anonymous Feb 01, 2009
    I have the same problem with my printer i had a paper jam and once i cleared it the printer kept on insisting that the back cover was open although it clearly wasn't
  • giac277 Apr 01, 2009
    Brother MFC7420 message "back cover" open when it's not
  • MC1834 Apr 03, 2009
    BACK COVER OPEN ERROR MESSAGE DISPLAYED AFTER CELARING PAPER JAM. I AM SURE ALL PAER IS CLEARED AND BACK COVER IS CLOSED...
I've had this problem for about a month and just found the solution. I hope you can follow my description...
Open the back cover; pull down the black, hinged paper guide.
You'll see a 1" lever sticking up in the center connected to a 5" horizontal bar.
About 3" to the right of that lever you'll see a tab protruding from the bottom of the bar. That tab needs to go into the slot below it. That just be the trigger/switch. Mine was dislodged from that slot. When I re-inserted it my problem was fixed.
Posted on Oct 31, 2008
  • mingala2000 Sep 05, 2010
    I love you, You solved my problem Thanks a lot a lot
I found that there is a optical switch on the right side as viewed from the back. This needs to be "blocked" by the plastic tab the moves in and out with the paper guide part. I saw that the small horizontal plastic bar has a small tab in the middle that was not inside of its slot. I moved it back into the slot and the problem went away. This problem was found on another brother printer and the fix was the same.
Posted on Jan 07, 2010
Thnx even tho i figured it out tht same night lol but thnx neways
Don't know how to open the back cover
Go 2 search in Youtube, type "how 2 open the back cover of d Galaxy Note", or "open box with the Galaxy Note" as easy as abc, wow!
Dec 28, 2012 | Cell Phones
OK almost a months ago on the screem shows the ; Back cover open- Close the back cover I couldn't find the back cover which is open what is that mean can you please tell me which is the back cover...
This happens to mine when it is actually paper jam in the back. Open the back cover, then open the black guard behind that then depress the two purple levers and pull out the sheet. Two people make it easier but I can do it myself.
Sep 05, 2010 | Brother MFC-7820N Printer
The printer says back door open when its not
Open the front cover and remove the drum and toner(cartridge) There should be a paperjam in the machine. It reads back cover open because the piece of paper is covering the sensor for the back cover.
Jul 14, 2010 | Brother MFC-7220 All-In-One Laser Printer
I had a paper jam and I had opened back cover to clear it. Now when I close it still says Back cover open. Close the back cover. What should I do? There is a black color flap inside the main back cover...
Just fixed the same problem. My solution was as follows: When you open the back cover there is another plastic flap/cover inside that drops. Across this 2nd cover there is a plastic rod running parallel with a plastic finger that sticks up perpendicular to the rod which I believe guides the paper into the roller.
On my machine this rod came out of line, placing it about a quarter inch to the left which affected the sensor and the guide. If you look closely, you will notice a small groove on the rod that needs to be in a specfic slot on the 2nd cover. Good luck
Jun 08, 2010 | Brother MFC-7820N Printer
Brother all-in-one printer not working; error 'back door open'
Open the front cover and remove the drum and toner.
Jun 02, 2010 | Brother MFC-7220 All-In-One Laser Printer
Back Cover Open Close The Back Cover Is Message I'm getting. What is the Problem?
Open the front cover and remove the drum and toner(cartridge).
May 31, 2010 | Brother IntelliFax-2820 Laser Fax
It says close back cover but back cover is already closed
Apr 19, 2010 | Brother MFC 7420 All-In-One Laser Printer
Fax display says, close back cover even with back cover closed.
Apr 15, 2010 | Brother IntelliFax-2820 Laser Fax
Brother MFC-7420 Fax Scan Copy
Maybe there is broken at the back cover try to check again the back cover,inspect the cover very well .
Nov 09, 2008 | Office Equipment & Supplies
1,903 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
