Question about Pioneer Audio Players & Recorders
My Pioneer M90 power amp started making very loud thumping noises when it was switched on, tried all inputs with was the same result. Failure of which component could caquse that?
Change filter cap
Posted on Aug 03, 2008
Transmission make loud sound when put it in revers
PLEASE HELP! SOS! car starts but doesnt move! - Club3G Forum ...
www.club3g.com > ... > Performance & Tech Forums > Problem Reports
Nov 16, 2010 - 61 posts - ‎14 authors
now yes, i will take the transmission is fubar into consideration but theres an .....however... idk about my cv joint, my car ONLY would make a loud ping noise when i move from a stop or brake ..... almost always when i put it into reverse. such as an engine mount sound, ... Vehicle: 2004 Eclipse Spyder GT. Loud knocking sound after oil change..
Sep 20, 2010
Horrible noise upon start when cold
Dec 24, 2009
Sporty knocking.. Oh noez!!one!!1!
Mar 22, 2006
More results from www.club3g.com
Loud thump when I shift into drive or reverse - CarGurus
www.cargurus.com > Questions > Chevrolet > Cavalier
CarGurusDec 19, 2012 - And while driving loud thump when car motor shifts th... ... Bad throttle position sensor can trip both lights and make the transmission shift at high rpms and shift hard even under light acceleration. .... the transmission will shift hard when firstput into reverse or drive ... 2004 Chevrolet Cavalier LS For Sale.Missing: mitsubishi ‎eclipse
Mitsubishi Transmissions & Drivetrains Repair Questions ...
Dec 06, 2015 | 2004 Mitsubishi Eclipse
S8 makes a very loud vibrating buzzing noise with only the power lead plugged in
Check for ground loops. Also shut off any CFL or LED lamps inthe vicinity.
You may also have an intermittent connection on the input.
There is a lesser chance that there is an internal failure of a capacitor on the amp power supply, but it is a possibility to look at if all the wiring is in place and soundly connected. The S8 has a high gain amp. It will pick up interference from CCFL or LED ballasting supplies it will also be able to pick up other switch mode power supplies. in vicinity of the input cable.
Jan 07, 2012 | Celestion S8 Subwoofer
Serial number 00-06778552, a gig amp manufactured about 1977/78, (used in an American tour in 1978). While running a practice session at low volume, the yellow DDT light blanked altogether (this has been...
The amp has a failure. One side of the power amp is starting to draw excessive current to the point that the filter caps can't sustain the current so the ripple starts to be heard in the speaker. Continued use MAY burn up the speaker by sending DC through it as well as causing additional damage to circuit boards, etc..
May 25, 2011 | Peavey Max 115 1x15 Bass Combo Amplifier,...
Bass speaker start up noise
Hello anne845,
It sounds like the installer wired the amp remote turn-on terminal to an "accessory" lead in your vehicle. Many stock radios do not have a dedicated amp turn-or lead and the alternative is to connect the amp to a switched power source (ignition or accessory). This means the amp turns on whenever you turn on the vehicle ignition, often resulting in a thumping from the subs. It is a perfectly satisfactory alternative, and will not damage either the amp or the sub. But it's irritating.
If the thumping is objectionable, have your installer wire a SPST (Single Pole, Single Throw) toggle switch inline with the turn-on wire. The switch should be mounted so it is accessible by the driver, and whenever you turn on the radio, turn on the toggle switch.
Hope this helps.
May 11, 2009 | Alpine SPX-17MB 300 Watts MIDBASS Speaker...
I cannot work out how to connect my pioneer C90 control amp to my pioneer M90 power amp
the audio output of C90 control amp.is in the>INPUT of your pioneer M90 power amp.
message me if ever not ok..
Jul 17, 2008 | Pioneer Audio Players & Recorders
Audio noise while car is on no prob in past
I've had that same problem before. What was happening is one of my amps safety cut off usually a built in surge protector basically, was coming on thus the loud thump. Most of the time when it comes on the amp goes off. Could be a power issue as well. Have your alternator checked too. Once your car is started it is run by your altenator so it could not being supply enough power. I fixed my problem by adding two 1 fared capacitor, one for each amp I was running.
May 20, 2008 | Car Audio & Video
The bass box
Hi Jamesroy,
Remove the Audio inputs from the bass box to see if the thump is coming from the Audio input. Of course do this with everything turned on. What we are trying to figure out is where the thump is originating from. If the bass box does not thump when the audio inputs are disconnected, the thump is coming from somehwere between the bass box and the circuits inside the head unit.
If you still have the thump after the Audio input wires are disconnected, then your bass box's amplifier has noise problem. You might try getting a noise filter from best buy to put on the power supply feeding the bass box.
Nov 30, 2007 | Pioneer DEH-P7400 CD Player
Sub thumps repeatedly
since it still thumps i suspect the speaker is ok, but i suspect you have an electronic problem in the amp. since it is a powered sup & has the ability to auto turn on it has electronic circuits inside, take it to a service center for an estimate
Oct 01, 2006 | Paradigm PS1000 Speaker
486 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
