Question about Amphion Mediaworks V101 DVD Player
Disc won,t play it just keeps spinning it says loading but it won,t play
  • Amphion Medi... Master
  • 6,993 Answers
how long have you been using this player and when did this begin?
The lens is weak such that it cannot load data on discs. Its spinning, trying to load, but can't because of the weak laser.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all discs again.
Good luck.
Posted on Jan 12, 2011
SOURCE:
The DVD keep spinning but won't play
see the next steps and fix it. God bless you
Clean a DVD disc:
  1. Hold the disc by its central hub and outside edge.
  2. Blow dust from the bottom surface with a can of compressed air.
  3. Clean dirt and fingerprints from the bottom surface with a lint-free cloth dampened with CD/DVD-cleaning fluid or denatured alcohol, wiping from the center outward.
  4. Clean the objective lens:
  5. Remove the housing and lift the hold-down clamp to expose the lens.
  6. Remove dust with canned air or soft brush. If needed, use a foam swab or a camera-lens tissue dampened with lens fluid.
Oct 03, 2012 | Mintek MDP-1070
Keeps on loading and never plays the disc
The only thing you can try is clean the laser lens with rubbing alcohol and a Q-Tip, allow several minutes to dry before testing, If this fails the laser pickup assembly will need to be replaced, a costly adventure.
Sep 18, 2012 | Audiovox D1917
My CD player keeps displaying no disk and wont play the cleaner disc, is something dirty or broken?
Hello
If it does not play the cleaner disc, just inspect whether the disc inserted in spins inside it. You can check this by open the upper cover of the player, and inserting a disc into it. If inserted disc spins inside, and the player won't read it, the fault is with its laser pickup unit, and it should be replaced with same type and number.
If the disc dos not spins, the fault is with the sled motor [the motor that spins the inserted disc], has damaged, and should be replaced. OK.
Dec 25, 2011 | Sharp Audio Players & Recorders
My DRC6309 RCA portable DVD player will not play disc. It says "loading" and then says "no disc". I have tried different outlets and different discs. Any suggestions? Is there a...
Hello
Either your DVD players Laser Pickup Unit is dirty or defective or its 'sled' motor has damaged. Sled motor is one, which spins the disc inside. if it does not spins, the main system IC won't get any signal that the disc is "IN", and will show the messege "No Disc". The same will happen if the laser pickup unit is defective or dirty. Insert a Head Cleaning Disc into the system, and play it for atleast 3 times. If there is any dirt or dust, this will solve your DVD's problem. If not, it should be serviced by any skilled technician. It is not a user reparable item, as you have to take out its loading mechanism completly out of it for repair. OK.
Jun 02, 2011 | RCA DRC6309 9 in. Portable DVD Player with...
Ps3 games won't load. it sounds like the disc is just tryin to spin then it does play after a reset to factory settings and i have to keep reseting it before it plays every time.
No spin or slow spin is related to the lens. The lens detects the disc and spins it. If the lens is dying these symptoms occur and the only solution is a new lens. This will run you about 50-60 dollars.
Mar 28, 2010 | Sony Playstation 3 (PS3) Console
Durabrand pdv 702 won's play all disks. will play recorded and some orginal but not all
If it only fails on home made discs the problem lies in how they were burnt.
Aug 22, 2009 | Durabrand PDV-709
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Nov 25, 2007 | Televison & Video
Amphion Mediaworks V101 DVD Player Logo
394 people viewed this question
Top Amphion Mediaworks Televison & Video Experts
Marvin
Marvin
Are you an Amphion Mediaworks Televison and Video Expert? Answer questions, earn points and help others
