Question about Maytag Atlantis MDG7400AW Gas Dryer
Mytag Dryer ModelLdg4000Aw
My Maytag electric dryer starts and heats, but will not shut off. Timer dial does not move. I replaced the timer and it does the same.
  • 4444567 Sep 05, 2008
    My dryer does a similar thing. The auto dry dials heat but do not shut off. My dryer ran all night before I realized I had a problem. Lots of heat but would not shut off. The other dial, timed dry/air fluff would shut off after the selected time but did not heat sufficient enough to dry.
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Posted on Jul 13, 2008
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ... > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Maytag quiet series 200 runs, dries but timer does not move and time out.?
Probably the timer motor is broken, or electrical connection bad. Probably need a replacement timer. OR something has wrapped around the dial shaft and is binding the dryer.
Feb 28, 2015 | Maytag Dryers
Dryer Tunrs on and runs with no heat and timer never moves
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Aug 02, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
The dryer timer will not advance in permenent press section of the dial. it works correctly on all other sections. i replaced the timer and the problem is still present
could you send the model number and is it gas or electric?when you have it on permanent press is there heat?usually the dryer heats,the heat shuts down and the timer moves,timer stops and the heat comes back on.could have a bad thermostat or thermister but i need the model number to see what is in your dryer
Jun 12, 2010 | Kenmore Dryers
My maytag dependable care plus electric dryer doesn't shut off
Does the timer move when it's almost ready to shut off if not most likely need a timer. Can you turn it by hand to finish the cycle and shut it off. If not must be timer.
Hope this helps
Apr 24, 2010 | Maytag MDG7600AW Gas Dryer
Dryer,timer switch won'tmove & cool air only.
Begin by replacing the times. Then you will most likely find that you are back in business.
Jun 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Timer runs continuously - Does not stop at all
There should be a timer motor on the timer. That is most likely burnt out and will cause the timer to not shut down. Just replace the timer and that will solve the problem
Jan 01, 2009 | Maytag Neptune MDE4000 Electric Dryer
Does the dryer dry fine? If your dryer is taking too long too dry you might have a venting obstruction that is not allowing the dryer too sense that the clothes are dry so the timer won't advance. Try disconnecting the vent from the back of the dryer and dry a load unvented and see if the timer advances.
Jun 11, 2008 | Maytag SDE3606A Electric Dryer
Electric Dryer problem
the timer has a small motor to advance the timer. the motor is the likely problem. on some old maytags you can get just the motor, but you probably will have to replace the complete timer. hope this helps.
Oct 25, 2007 | Dryers
Maytag Atlantis MDG7400AW Gas Dryer Logo
552 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
