Question about Sony VAIO PCG-V505EC Notebook
Increase ram for vista ulimate
Replaced xp with visat ulimate. notebook has 512mb ram. will adding 2gb memory stick speed up system ?
  • Anonymous Mar 13, 2014
    2GB RAM Memory for Gateway SX2801-07e
  • 54 Answers
Yes surly it will have some difference but make sure that your laptop has 2gb ram support sorry for the late reply
Posted on Sep 23, 2008
Upgraded ram 1gb wont boot hp 510 mobo 30C4
If you added another 512Mb RAM to increase the RAM to 1Gb then the new 512Mb memory stick could be incompatible with the original 512Mb or it could be faulty.
Use RAM that is same make and speed as the original RAM.
Remove both RAM and just insert the new 512Mb into your laptop and see if the laptop boots up, if not then the RAM could be faulty.
Mar 02, 2013 | HP 510 Notebook
Want to upgrade memory to 2 GB. Desktop will not post up with 2x1GB cards. Every 2-3 seconds it makes a sound/tone. The fans would turn on but there is no signal to the monitor. However, it will post up...
There is no reset just because you added memory.
If you have 2- 1GB sticks, try both , one at a time.
Your system spec's and manual tell nothing which dimm banks are suppose to be used , and if you can install 2-1GB sticks,
all it says is it can handle 2GB.
Now it says 512MB, sticks, this could mean you can only use 4-512MB sticks to get too 2GB,.
Now it does not tell which dimms are used if you have 2-1GB sticks,
You have 4 slots, the first two and the second two, most times, you either use the second bank of each pair, or the first slot of each pair,
but as I said, your system does not say.
So you can try both ways and see if one of them work.
Sorry I can't be of more help,but you system has a poor manual
on memory placement.
Feb 14, 2010 | E-Machines T3302 PC Desktop
Acer Aspire 5601 4GB memory upgrade problem
Acer systems are picky about the type of memory you use.
What is your RAM Speed on the old chips compaired to the new chip
You may have to reorder the same type of speed memory
Try this website it will tell you what will work with your system
http://www.ec.kingston.com/ecom/configurator_new/mfrmod.asp?root=us&LinkBack=http://www.kingston.com
Aug 22, 2009 | Acer Computers & Internet
Adding memory, new total not recognized: IBM Thinkpad R51e-1844
Ram should always be paired. Same type, speed and size in each slot. You may have 1 SIMM/DIMM/DDR that has 2 sides of chips and the other with 1 which will do exactly what you state. RAM reads across the chips simultaneously. So if you have a different one in each slot it can go bonkers and do goofy stuff on you.
Jun 14, 2009 | IBM ThinkPad R51 Notebook
Can the memory be upgraded (increased) from the basic (factory installed) 512mb on the Sony PCV-W300G?
Hi there.
As far as i know you can upgrade the RAM to 2GB, 2x1GB 184pin PC2100 DDR DIMM Desktop RAM modules is what it can take.
Thanks for choosing FixYa!!
May 28, 2009 | Sony VAIO PCV-W300G PC Desktop
Problem with upgrading my acer extensa 5620z memory to 4GB
Hi there.
I recommend you get another stick of SODIMM to replace what seems to be the faulty stick.
If you are using XP or Vista X86 (32bit) then the system will only recognize 2.8 - 3GB of memory, only 64bit operating systems recognize the full 4GB.
Good luck ad thanks for using FixYa!!
May 24, 2009 | Acer Extensa 5620 Notebook PC
I need a laptop having onboard dedicated memory of 256 mb.show me the models available in indian market and price also.
MOST LABTOP HAVE A PANEL ON THE BUTTOM OF THE MACHINE AND ON THAT PANEL SHOW A LITTLE ICON THE SHAPE OF MEMORY CHIP ON A STICK, 2 SCREW THAT ARE A PHILLIPS HEAD, DEPENDING ON WHAT MAKE YOU WANT AND WHAT OPERATIONAL SOFTWARE OR WINDOWS VERSION WILL DEPEND ON AMOUNT OF RAM, IF YOU OPEN YOUR UP IT MAY HAVE 2 CHIP SET AT 125MB, OR 1 CHIP 250MB, THAN 512MB, 1GB, 2GB, XP VERSION NOT MORE THAN 1GB BECAUSE THE SYSTEM CANNOT HANDLE THE SPEED AND YOU WOULD OVERCLOCK MEMORY.
ADDING ANOTHER 256MB WOULD BE FINE, COUNT THE NUMBER OF PINS AT THE BUTTOM OF THE CAED WHERE IT PLUG INTO THE LABTOP, OR LOOK ON THE MEMORY STICK AND LOOK FOR THE NAME OF THE MFG AND EMAIL THEM ON A PRICE TO INCREASE THE MEMORY, AND YOU MAY SAVE ALOT OF MONEY IN THE LONG RUN.
GO ON LINE TO WWW.FRYS.COM, THEY HAVE THE BEST PRICES AND ALL THERE MEMORY HAVE A LIFE TIME WARRENTY WHEN YOU BUY FROM THEM.
IF YOU NEED MORE HELP WITH YOUR LABTOP OR PC YOU CAN CONTACT ME THREW THIS WEB SITE
@ RODGANDYSR
CANDYMANGANDY
Mar 12, 2009 | HP Pavilion dv6000z Notebook
My1 gb ram didn't make any change even in games in my pc even those games which used to run at a particular speed earlier before the added ram are running just like thet speed even after adding 1gb more...
Ok, let's explain this. RAM does not necessarily make your pc faster.
Your pc can be faster if you upgrade your CPU or graphic card(only graphic application will make you notice the increased speed in graphics).
RAM can be a bottleneck for application that need a lot of memory like photoshop when working on multiple very high resolution images or 3D cad when working on large assemblies, or VMWare.
Vista manages the RAM in such a way that you might notice a slight performance increase and less disk usage during standard desktop activities, but XP doesn't.
if you don't use very many applcations at a time and/or you don't use memory consuming applications, the added RAM is not used at all and your computer won't be any faster than it used to be.
Video memory is basically the same. you will notice a difference in performance from a large video memory(512MB-1GB-2GB) only if you game at high resolution like 1080p or higher, usually supported only by large monitors like 20" or larger.
Feb 19, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Memory confusion different readings
It sounds like something isnt working right, what operating system are you using, Vista? I would take out the original 512 and see what it says after, often ram isnt compatible if it is too different in size and speeds. Also, if your motherboard supports dual channel ram and you have the extra 512 chip it wont run in dual channel mode, you would run better with just the 2 chips then the added 512 chip.
Jan 17, 2009 | Mach Speed (S755) Motherboard
IBM ThinkPad T40 2GB Max RAM
The T40 has two ram slots, you can put a 1g chip in each totaling 2g. If the chip will remove, then it is changeable. Vista needs a minimum of 256 to run, so, when you change BOTH chips to equal 2g it will probably read 1.744g, or it may read the full 2g. If it only reads 1g, then the second slot under keyboard may have malfunctioned. It could also be that the 256 chip is bad and your really only running 512 now. With all that said, in order to achieve 2g, you will need to put a 1g chip in each slot.
Jul 08, 2008 | IBM ThinkPad T40 2373 Notebook
Sony VAIO PCG-V505EC Notebook Logo
71 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
