Question about 1Way Remote Transmitter
How to program new remote to alarm - 1Way Remote Transmitter
    New Friend:
  • 103 Answers
TRANSMITTER PROGRAMMING Note: System can learn up to 3 different codes max. 1. Turn Ignition ON and OFF 3 times quickly, leaving it ON the 3 rd time. (ON/OFF, ON/OFF, ON) You should hear (1) short chirp. 2. Push the Program/Override Button for 5 seconds until the siren chirps (3) times. Release the button. The system is now in programming mode. 3. Press Button #1 on new transmitter - siren will chirp to confirm programming. Repeat Step 3 within 5 sec. for up to 2 additional transmitters. 4. Turn off Ignition. Note 1: If only one transmitter is being programmed, continue pressing button #1 until dash LED flashes goes out and the system chirps to exit programming mode to prevent unauthorized codes and noise from entering the system. Note 2: Programming mode is exited automatically after 5 seconds of last code transmission or once 3 new codes have been programmed. The LED will flash (4) times indicating program mode exit.
Posted on Jan 12, 2011
SOURCE:
2001 maxima alarm not working but panic works
ck for a fuse in the under the hood fuse box that says bsm may be blown.
Also try this.....
To reset the security system remove the negative battery cable for 30 minutes, then reconnect the cable. Next, lock and unlock the doors using the remote. This will reset the alarm system and the engine will start and fobs reset.
Here are some factory notes....FYI
Anti-Theft Systems
PROGRAMMING
NOTE: If a new Smart Entrance Control Module (SECU) is installed, a new identity code must be entered and all remote controllers must be programmed. If identity code cannot be entered, repair multi-remote system. See appropriate MULTI-REMOTE CONTROL SYSTEMS article.
PROGRAMMING > PROGRAMING NEW ID CODE
NOTE: This procedure will erase all previous identity codes and render all previously programmed remote controllers inoperative (until reprogrammed). All remote controllers to be used with system must be programmed at the same time. A maximum of 4 remote controllers can be programmed. Any attempt to program more than 4 controllers will be ignored. If same identity code is entered more than once, entry is ignored even though hazard warning lights will still flash twice.
1. Close and lock all doors. Erase original identity code(s) by inserting and completely removing key from ignition switch more than 6 times within 10 seconds. Hazard warning lights should flash twice. Turn ignition switch to ACC position.
2. Push any button on new remote controller once. Hazard warning lights should flash twice, indicating identity code has been entered. If identity code cannot be entered, repair multi-remote system. See appropriate MULTI-REMOTE CONTROL SYSTEMS article.
3. For each additional remote controller to be programmed, manually release door lock and lock again by using door panel switch and repeat step 2. If no additional remote controllers are to be used, exit programming mode by unlocking and opening driver's door.
Please let me know if you need anything else to get the problem fixed. Happy mew Year!
Jan 03, 2018 | 2001 Nissan Maxima
Can a new remote be programmed if alarm is set?
Hi Kim, When you ordered the new key the dealer should have asked for the chassis number? That gives them the codes to pre program. so that it should activate and deactivate the alarm, if that is the problem! ? Regards John
Jul 02, 2012 | 2000 Pontiac Grand Prix
I have a ford explorer 1994 i lost the control remote, Installed a new alarm, but technician can not uninstall the factory alarm How can I do this? when new alarm is on, and opened the doors whit new...
Why not just get the factory PATS System working correctly. You can't remove the factory system,it's an integral part of you vehicles systems and processors
You can get new remotes and program them!!
May 26, 2010 | 1994 Ford Explorer Limited
LOST KEY AND REMOTE TO A 1996 DODGE CARAVAN, i WENT TO DODGE TO HAVE NEW KEY MADE AND WAS GOING TO GO BACK FOR NEW REMOTE, HOWEVER IN THE MEAN TIME i LOCKED VEHICLE AND NOW IT WON'T REPROGRAM BECAUSE IT IS...
If unlocking the Van via the door locks wont disarm the alarm it's because the alarm harness have become detached. The door panel will have to be removed and the harness manipilated manually to disarm the alarm. Or you can have a new remote programed
Apr 29, 2010 | 1996 Dodge Caravan
I lost my remote for my viper 350 hv,and when i used my key to open the door the alarm went off,and disconnect the viper box,and bought a new remote,and when im trying to program my new remote and plug my...
You have to turn your ignition on and press the valet button switch, to turn off the alarm. Then, you have to use that same valet button to learn the remote to your alarm, following the steps in the installation manual.
Sep 20, 2009 | Viper Security and Remote Start System...
Saturn won't start/ key problems
You need to program the system,it's probally in theft deterrent mode & disables the starter.To program your new remote locate the diagnostic connector under the drivers side of dash.To program the new remote Jumper a paper clip between the #4 & #8 terminal you will hear the locks cycle & the trunk will pop.While the terminalsv are jumped hold down lock & Unlock on the remote at the same time until you hear the locks cycle again,remove the jumper wire or paper clip & you should be good.
May 19, 2009 | 1997 Saturn SL
REMOTE DOOR LOCK 1997 ES 300 LEXUS
Even if the remote is fairly new they can lose their programming you may have to have it re-programed
Mar 17, 2009 | 1997 Lexus ES 300
1996 Grand Cherokee keyless entry problem
That remote should not be able to  be programmed by you, it needs to be programmed by the dealer using their computer.  I know that some later and earlier models can be programmed by the user, but I did some research on this as i have a 96 as well and it seems the 96 was a dealer computer thing.  If you in fact bought the remote from the dealer they should be willing to program it for FREE.  Otherwise I was given a $30 estimate for the programming.
Dec 07, 2008 | 1996 Jeep Grand Cherokee
94 jeep GC alarm problem
Hi....
To program the RKE (remote keyless entry) on your jeep g cherokee 94.
Follow this steps.
But maybe you will need to do more than one time.
Because some times require a few intents.
but if you have 1 remote programed all ready. you will program up 4 remotes.
If you don't have any one programed and you can't programed with this steps.
You will need to BUY the RECEIVER that is located on the ROOF CONSOLE.
Because some times come damaged....
081c5be.jpg Ok. I hope this work for your problem.
Thank you for use fixya.
Sep 11, 2008 | 1994 Jeep Grand Cherokee
1Way Remote Transmitter Logo
2,131 people viewed this question
Top Crime Stopper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
David Thompson
Level 1 Expert
Alli Abiola
Alli Abiola
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
