Question about Toshiba REGZA 47HL167 TV
Model: 55SV670U The screen has horizontal black lines that flicker at various times when watching various sources, DVD & Satillite TV. Does not happen all the time. Tried turning off the set and then restarting, that worked for a while, but now it does not normally work. Again, it does not happen all the time just happens at random times.
SOURCE:
bestdarngood
  • 3037 Answers
SOURCE: horizontal is flickering
flickering as the picture becomes smaller and bigger or are there lines showing up? Please describe it better if you can so I know exactly what you are seeing. Any color changes?
Posted on Jun 28, 2008
SOURCE: Poor picture quality on Toshiba Regza 32AV555DB LCD TV
i had the same problem! i just changed my scart leads to some quality gold ones, this made the picture a lot crisper . hope this helps :0)
Posted on Apr 30, 2009
  • 4090 Answers
SOURCE: Flashing power button tv won't turn on
yes call the tech and have the power board replaced. In future have the TV plugged into an anti surge board to protect it ( and you from expensive repair.) I suspect you will need a new power supply fitted
Please rate the help to keep us online
Posted on Aug 17, 2009
  • 8457 Answers
SOURCE: My 42 inch toshiba plasma tv. about 4.5 years
Ur backlight video inverter board is dead or defective,need it replaced.Tries these websites Shopjimmy.com or Partstore.com or Ebay.com.
Posted on Sep 29, 2009
SOURCE: Regza intermittantly blacks out. Can be when it
Repaired a Toshiba 32hl67 by reseating the connectors on every board and cutting the wire tie on the back of the screen. I know it sounds crazy but I think the wire tie is what did it. I think it put enough pressure on the wires to cause just enough disruption in the currant flow to make the control board think something was really wrong and it shut down the screen as a safety measure. What every the case the TV work flawlessly now.
Posted on May 09, 2010
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
Samsung tv has flickering lineswhile watching tv
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec How to Fix Samsung TV Flickering Blinks Flashing Flat Screen ... Rating is available when the video has been rented. ... sorry to bother you tampatec but i have a RCA tv it works great when it's.... My Toshiba Full HD led tv model 32PT200ZE is having issues of screen blinking/flashing and horizontal lines.
Sep 25, 2015 | Samsung Televison & Video
Lcd tv horizontal lines
This problem and solution were posted previously. The following is the link:
http://www.fixya.com/support/t7775296-model_55sv670u_screen_horizontal
Dec 25, 2013 | Toshiba Televison & Video
How do I find out how to put the tv on the right input on an older model phillips tv
Look on the back of the tv, the sockets that various leads are plugged into will have names next to them e.g. SCART-1 or AV - IN or RF IN. Make a note of which socket is used by your DVD player, VHS etc. with the TV on, switch on the device you want to use, let's say you want to watch a DVD. Some DVD players send a signal to the TV and the TV will automatically switch to the correct channel. If not you will have to select the channel manually. On the remote for the TV, look for a button marked "AV", "AV IN", "INPUT" or "SOURCE" press this button and you will either see a list of possible inputs, in which case, choose the correct one for your DVD player - e.g. SCART-1. If you don't see a list, the screen should flicker, go black, blue or straight to the DVD player. Keep pressing the button until you get to the desired input channel. To go back to normal tv, press TV on the remote or you may need to press the input button a few more times - depending on your tv.
Apr 05, 2011 | Televison & Video
Toshiba 32A35 Color TV Flickers & Scrolls w/ light colored images
My Toshiba 27" tv has the exact same problem any solutions out there or is it time to toss the tv?
May 24, 2010 | Toshiba MV19H1 Combo
Hi! I was watching my TV - Samsung LN-S4092D - and the picture went to black with a few very light horizontal lines for about 30secs. After that it went to complete black. I thought it might just be that...
Hi Bob. The first Board to cause this problen is the Main bd. The next bd to cause this is the T-Con bd which is mounted on the Panel. Since you saw horizontal lines and that you have text on the screen and are missing audio from the tv means that the Main bd has gone bad. Have a trained Samsung tech service your tv. Call 1-8020-Samsung as they can direct you to a Qualified tech in your area.
Jul 05, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Bottom of screen flickers, and eventually the screen 'freezes'
they have problem lines in tv screen harizontall lines how i can fixed in HDTV prima 29inch.2008 model .give me ANSWER .
Jan 17, 2009 | Prima CV2011 TV
Faint horizontal lines in picture
This is usually caused by a problem in the Horizontal Output section, around the Horizontal Output transformer usually a capacitor or diode going or gone faulty... the line you see are the Horizontal "Retrace" lines that are useually "Hidden" when the circuit is OK..
Jul 30, 2007 | JVC AV-27320 27" TV
Toshiba REGZA 47HL167 TV Logo
269 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
