Back to:
Tags:
Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 Power Supply
posted by Kkrat505 on Jul 13, 2008
When I press the power button on my Sanyo DP32746 I can hear the power relay pull in. After 10 seconds the relay drops out. During the 10 seconds the relay is in, there is no picture (screen stays dark) or sound. After attempting to power up the set 3 or 4 times the relay stops pulling in all together. If I unplug the set for a few minutes and plug it back in I can get the relay to pull in again for 10 seconds. I realize the relay is dropping out as a protective measure. Has anyone had this problem and been able to resolve it? Is there a particular module that I can replace to get the set working again?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Flat Panel Televisions problems?
Turning on flicker then no picture. Had sound. Pushed...
I have a 32 inch Sanyo model #DP32746 that wont power up....
i need a replacement screen for a Sanyo DP32746. are there...
Picture went black, sound is good. Assume from my research...
for remote
Loading problems.
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
