Question about Whirlpool Washing Machines
Flashing suds and unsble to stop machine - Whirlpool Washing Machines
  • Anonymous Mar 26, 2009
    Thanks for the information fixed the problem!!!!!!!!!!!!!
    I feel sorry for the Appliance techs
  • 5,911 Answers
Please click on the following for an explanation of the SUDS error:
http://www.fixya.com/support/r629564-suds_error_whirlpool_kenmore_front
Read through the link provided and let me know if you still have questions. I hope this helps you.
Posted on Jul 13, 2008
What does it mean if the washer is not draining and has a flashing f where the time shows?
I have the manual for this machine. Under "Code 21" it says the following:
"F21" (Drain Problem) Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Is the drain hose kinked? Is the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96" (2.4 m) above the floor? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service.
For "SUDS" code, the following:
"SUD" (Suds Routine) When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SUD" is displayed during rinsing to inform you that Suds Routine was activated. Use only HE (High Efficiency) detergents.
Here is some more information that may help you as well:
"F" Codes other than F20, F21 and F22 Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
I hope this is of some help to you, Please rate and comment, Thank You
Joe
Sep 07, 2011 | Kenmore HE2 Plus Front Load Washer
It flash's SUDs during the cycle.what does it mean and what can i do to stop it from doing it
The SUD message indicates the control or pressure switch senses suds in the water. Run the machine empty with hot water only to clear any soap residue out of the machine. Cut back on the amount of soap used and use only HE detergent in the machine.
Jan 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool calypso gets a co sl
“SL” is displayed if suds are detected but the unit is unable to clean it out. This may indicate a bad pump, an extra heavy load, excessive detergent or excessive suds. Press STOP/CANCEL to clear the display then run the machine with few number of clothing and do not use detergent. This is to verify if overloading or suds are indeed causing the problem or not. The problem is a bad pump if the fault code still flashes.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You can continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Aug 03, 2010 | Washing Machines
Son put normal dish washing liquid in top draw!
ok, the machine flooded and the water has leaked into the bottom of the machine, 1st turn off the machine at the power point. 2nd- open the top drawer and remove the suds from it. 3rd. open the bottom drawer and look under it to the bottom of the cabinet . that is where the water will be. use a torch if you have to. now you need to dry the water up. you can do this with a hair dryer or a fan heater. the reason the machine is flashing F1 is because the water has triggered the flood switch and you need to dry up that water. please reply 4 more help.once dryed F1 will disappear. please make sure all the suds are removed from the top drawer. good luck
May 14, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hit pause to add other clothes to the cycle, stopped running and now flashing sud and nothing happening. can't stop the machine to start over
Hi
This happens when SUDS LOCK (Overdose of Detergent detected during the Wash Cycle). The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds. You need to follow these steps:
  • If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check Drain Pump
  • Check Pressure Switch
  • Check CCU
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Washing Machines
What is code F35 on a whirlpool washer model wfw9600twoo
It's a general code for some electrical system problem. Ours flashes "SUD" before while the machine is on before flashing "F35" when it stops. I've tracked this done to being a problem with the pressure sensor switch in ours, and it appears to be either from obstruction from too many suds (like using the wrong detergent), or an actual sensor problem. I followed online advice to pull the tube and blow back to clear any suds out, and that cleared it for one cycle, but then the problem came back, so I'm either going to try some other things to clear before calling for a service person to replace the sensor. The part is W10156252 Switch, Analog Pressure Sensor, number 20 of the washer parts diagram.
Jul 29, 2009 | Whirlpool Washing Machines
WONT RUN COMPLETE CYCLE WITHOUT F-2 OR SUD
sounds like you have a clogged/bead pump. removethe lower acess panel and from there youll see the pmp clean put remove thescrewout, and clearthe debris. BE WARNED THER WILL BE WATER BEHIND grab a towell or 2
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Persistent F02 / SUD error. Tried all the tricks!
how about the line from pump to bottom of tank?not excess suds?might be bad control bd..f code is generated when control bd senses incorrect current draw by drain motor ..could be glitch in readings or a misread
Nov 02, 2008 | Kenmore 4292x Front Load Washer
Washing Machines Logo
160 people viewed this question
Dan Webster
Dan Webster
Sal De
