Fixtures are covered by Lithonia Lighting 24-month warranty against mechanical defects in manufacture.
All life safety equipment, including emergency lighting for path of egress must be maintained, serviced, and
tested in accordance with all National Fire Protection Association (NFPA) and local codes. Failure to perform the
required maintenance, service, or testing could jeopardize the safety of occupants and will void all warranties.
Note: Specifiations subject to change without notice.
Actual performance may diffr as a result of end-user environment and application. Standard Catalog Supply Input Pallet Carton Number UPC Description Voltage Wattage Qty. Qty. ECR LED M6 784231874516 Red 120/277 3.8 108 6 ECG LED M6 784231874592 Green 120/277 3.2 108 6 ECR LED HO M6 784231874561 Red, high output 120/277 3.8 108 6 ECG LED HO M6 784231874615 Green, high output 120/277 3.2 108 6 Accessories: Order as separate catalog number. ELA WG3 Wireguard (back mount only) 1 ELA LED M12 Single remote lamp2,3 ELA LED T M12 Double remote lamp2,3 ELA LED WP M12 Single, weather-proof remote lamp2,3 ELA LED T WP M12 Double, weather-proof remote lamp2,3 Notes 1 See spec sheet ELA-WG. 2 See spec sheet LED-Remote Lamps. 3 Only available with HO option. 11 5/8 " 7 3/16 " 1 5/8 " Integrated Exit-Unit Combo 12-5/8" (32.1) 8" (20.3) 4-3/8" (11.1) 5-3/8" (13.7) 1-7/8" (4.8) LED Unit LED Combo LED Exit 15 (38.1) 3-3/4 (9.5) 5-3/8 (13.7) 12 (30.5) 3-3/4 (9.5) 2 (5.1) 2" (5.2) 4-1/2" (11.4) 9" (22.9) 8" (20.3) 20" (50.8) 12" (30.5) All dimensions are inches (centimeters). Shipping weight: 3.6 lbs. (1.6 kgs.). ECR LE
Look for the wires leading to the light on the 2000 Cadillac Deville.
Try to figure out which one leads to the 'white' light that is for backup.
If there is a replaceable bulb, then there should be a way of rotating a socket out from behind.
Some Devilles have LED lighting for the red brake lights, I think.
open up you pc case...mind out for static! dont touch what you dont have to and look for a printed ( normaly white ) motherboard model id..this might be the name of a manufacurer or just a few letters and numbers plus a revision number at the end. armed with these, trot of to google and stab them in. you should see a host of sites, but look for one that is the support site for your board...track down you board on the support/download site and there should be a manual & drivers ect to help you :)
the security code for your nokia 1200 is 12345, if it does not work
then the master code for IMEI 359820012968226 is 0510516213
if this does not work, then you need to send your set to any service center
for factory setting, take care [email protected]
Intermittent won't start, power supply LED's may be intermittent
Cause: Power supply regulator I901 P/N CZ00868 is leaky, may verify the problem by freezing I901.
