Question about Canon NP 6551 Black and White Copier
Canon copier NP 6412
My canon copier prints sometimes and it stops at time and give me this error code E8 and then blinks and shows me 03
  • Canon Expert
  • 1,326 Answers
It is a older copier, it could be a fan is not working, is it making noise. It may be failing......
Posted on Jul 23, 2008
Why my canon ir1133 printer is showing e733/0000 error message?
ERROR E733-0000 Stops printing and shows sign "Turn ...
www.fixya.com/support/t21602993-error_e733_0000
Nov 20, 2013 - ERROR E733-0000 Stops printing and shows sign "Turn main power ON". Error ... error message when printing d1350 imageclass. Jan 03 ...
Oct 29, 2015 | Canon imageRUNNER 1133 Laser Multifunction...
Error E8 HP Laserjet MP1136
See this... http://h30434.www3.hp.com/t5/Other-Printing-Questions/m1132-hp-printer-gives-me-e8-error-code-is-it-expensive-too/td-p/907661
Jul 04, 2014 | HP Office Equipment & Supplies
E 210
there is an lance home position sensor problem... open the platen glass, then open the lance cover (black Metal).. then turn on the machine and check the lance is moving forward and back to center.... if not clean the lance home position sensor or replace that.....
Nov 28, 2011 | Canon NP 6050 Copier
An error occured we cannot print a document which the orange light was blink semoustanousely
Damage canon printers, can be identified from the number of lights blinking in orange. So, you calculate, how many times the orange light is blinking. Example E2, E3, E4, E5, E8, E9, E13, E14, E15, etc.
Problem
For
the error code E13 = The following ink may have run out black/color
Solution
Press and hold the Reset button about 10 second. E13 error on canon pixma, occurs twice. E13 for black cartridges, and E13 for the color cartridges
Nov 25, 2011 | Canon Pixma iP2700 InkJet Photo Printer
We want error problem ofter switching blinking red print key without warming and function 4 delate error not any function by copier
First you need to let us know what the error code is displayed on the display screen. With that there is a starting spot, then will be able to move closer to solving the problem...
Oct 10, 2009 | Canon NP 6050 Copier
Canon copier np 6412
wow that is hard to do i made the mistake doing that one time promised myself never to do that again took me quite a while to get it back in i dont know of any trick except persisitance just dont let the springs come off
Oct 27, 2008 | Canon NP 6551 Black and White Copier
Canon pixima mp140 error code E4
following error codes i found
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
Apr 24, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon mp160 E2; printer won't re-set
hi dear
may the error code or how many blinking can solve your problem
this is the list of error code
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
try this methode
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED
lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
cropp
Feb 16, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Ploblem
the error code you are refering to is not an inverted 83 is in actuality an E803 flashed by an E8 followed by an 03.Basically your 24V dc is either being shorted somwhere internally or the DC controller or composite PCB needs to be replaced in either case the cost associated with replacing either curcuit board would far exceed the value of the copier.
Nov 27, 2007 | Canon NP 7130 Black and White Copier
Canon NP 6551 Black and White Copier Logo
243 people viewed this question
old marine
old marine
