Question about Dell Inspiron 6000 Notebook
Windows program shut down Laptop problem model-no-XPS M1530
A problem has been decated and windows has been shut down to prevent damage to your computer.
CONFIG_LIST_FAILED
If this is the first time you've seen this stop error screen. restart your computer. If this screen appers again. follow these stepes:
Check to make sure any new hardware or software is properly installed. If this is a new installition, ask your hardware or software manufacuturer for any windows updates you might need.
If problem continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as catching or shadowing. your computer, press F8 to select advanced startup options, and then select safe mode.
Technical information :
*** STOP : 0x00000073 (0xC000017D, 0x00000004, 0xF6D8ABB8)
Beginning dump of physical memory
Physical memory dump complete.
Contact your system administrator or technical support group for furtherassistance.
THIS IS THE PROBLEM THAT COME'S WHEN I START THE LAPTOP
  • 5 more comments
  • ChillyChill Nov 15, 2008
    I am trying to run Pro Tools and I bought this laptop specifically to do just that.  I have tried to install everything but I think I still need to disable the bios memory such as caching or shadowing and enable the bus mastering.
    Can someone please help?
  • guruprasanna Nov 16, 2008
    HI ,
    Even i have also got the same problem in my Dell laptop, Inspiron 1525.
    I shut down my laptop and when i got the error, then try to restart i was not able to dobysafe mode or anyother way.
    Please help me in resolving the issue.
    Thnx in advance.
    guru
  • snowshoe650 Mar 16, 2009
    I have the same problem - is there any way to save info from the hard drive? My 13yo has been writing a story (home schooling) for the past 7 months, and forgot to backup. Is there any way of getting his story off before wiping the hard drive?
  • Anonymous Apr 02, 2009
    mine says the same thing i have a dell inspiron 1525
  • dheepshek Apr 06, 2009
    I have a laptop windows XP OS. I am facing a problem with a blue screen on windows startup which says 'Config_list_failed' . Can someone guide me onto how I can solve this issue.
  • John Blake May 11, 2010
    Do you have disc
  • Zac Moore May 11, 2010
    Did Windows come installed on the computer, or did you install it yourself?
    Problem Solver:
  • 28 Answers
Sounds gooood
Posted on Jul 15, 2008
    Genius:
  • 2,028 Answers
As with any blue screen, this is an operating system error in which a driver or program has overstepped it's boundries by writing into an unauthorized section of the memroy, therefore causing the memory dump. You will need to run a system repiar or reload with your recovery disc or operating system disc in order to cure the problem. Start with the repair, if the rogue still persists, then you will need to wipe the hard drive and reload the operating system.
Starting Windows
In that case, I would reinstall Windows. Something must corrupted in windows. Do you have your OEM Windows disk with you?
Sep 06, 2012 | Dell XPS M1530 Laptop
I downloaded a game from GH which I played but once I shut down by laptop and tried to restart the next day I noticed the graphics were greatly enlarged and the laptop shut down. Now when I try to start...
hi
before starting windows press f8 then safe mode
when windows started chang the resulotion to lower mode and restart
if still the problem safmode - uninstall vga driver > restart > install vga driver again
by
Nov 02, 2011 | Dell XPS M1530 Laptop Computer PC...
Dell xpsm1530 drivers for win xp
Dell XPS M1530 Drivers for Windows XP are available at the following sites
http://www.notebook-driver.com/dell/dell-xps-m1530-laptop-windows-xp-drivers/
http://www.getpcmemory.com/drivers/download-dell-xps-m1530-notebook-windows-xp-drivers/
http://forum.notebookreview.com/dell-xps-studio-xps/254815-xps-m1530-windows-xp-driver-pack-final-udi.html
Hope it helps! Good Luck!
CreativeTECH
Mar 04, 2011 | Computers & Internet
I have a Dell XPS M1530 laptop and a few days ago I replaced the cmos battery and it worked; now it won´t but up. it started shutting down, now fan runs for 2 seconds lights come up but no display and...
Is it charging? If it isn't then try a different charger but reopen it and clean it with a soft brush and try again otherwise it looks like you've a PSU fault there and you have either disconnected or caused static damage to the system.
Sep 17, 2010 | Dell XPS M1530 Laptop
Dell XPS M1530 Ethernet Issue
change power option to maximum instead of dell recomended
Feb 04, 2010 | Dell XPS M1530 Laptop
it sounds like the hard drive might be failing or it might be a software problem. Try starting in safe mode and running a full system scan to see if it's sometihngi n the software. If not go to the Bio's screen and run drive self test. you do this in bio's by scrolling with your arrow till you get to a tools menu and then it will say hard drive self test. Your computer then will do 3 tests to determine if you have a harddrive problem. If you do then you will have to have the hard drive replaced. If you have a warranty on the computer call them as they will cover this issue.
Apr 02, 2009 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Hy guys...I have reinstaled my windows on my M1530 and I need the driver and program to activate and use my Infrared Port.Please help me with a link or something.E-mail: manu_grim@yahoo.com Thanks...
u just go through google and write there " driver for infrared for ****[ your model number ] for windows or vista u will defenetly get drivers...........
Mar 03, 2009 | Dell XPS M1530 Laptop
Dell XPS M1530 trouble shutting down
Try this, just to see if the shutdown actually works.
Open a command prompt and enter the following:
shutdown -s -t 05
-s is to shutdown, -t 05 is a 5 second countdown.  Let me know if it actually shuts down.
Feb 02, 2009 | Dell XPS M1530 Notebook
My XPS M1530 frezes up
it is internal problem related to the mother board
it is due to overheating
please get it repaired
Nov 08, 2008 | Dell XPS M1530 Laptop Computer PC...
Dell Inspiron 6000 Notebook Logo
493 people viewed this question
Alun Cox
