I have a Certikin Genie swimming pool boiler that is showing the word GAS and i can smell it. What should i do?
  • 3 Answers
You could try resetting this as it could be caused by several factors (blown heat exchanger being one as Karl mentioned).
Hve you tried resetting from in Service Mode ?
To get to Servce mode you need to go ino User Setup Mode first (turn off the boiler via the panel switch - then hold the Lock/Reset button whilst turning back on). Once in User Setup Mode if you rotate the thermostats all the way clockwise (it should display the software version) Then press and hold the Lock/Reset button for 3 seconds.
This should put you into service mode and it is now possible to change/reset some of the control parameters.
If you try resetting the error.
This issue may be caused if the Flue or water stat is tripped (in which case reset the stat). If th Fan resistor remains open in the circuit then you will need tsomeone out to investigate as that may cause the GAS error too.
COuldalso be the Valve coils are faulty in wich case they need replacing (agians I would get an engineer outto confirm and do that).
I'm suyou probably tried all this but just in case...
If the roblem is solved can you advise what fixed it ?
Thanks
Posted on Jul 01, 2013
    Welcome Back:
    Visited the website for 2 consecutive days.
Old one this question, but i have the same problem.
have checked stats ok.
it fires, but dies again.
it did run ok yesterday
What solved the starters problem?
Posted on May 04, 2017
My genie 35 is not lighting up what could this be can any body help
Posted on Jun 13, 2010
Sounds like you have 2 seperate problems here. The fault code GAS means that the boiler has failed to ignite. There could be various reasons for this so you really need to have it tested. Sometimes a leaking heat exchanger will cause this fault code to come up as well. A quick test to see if the heat exchanger is leaking internally is to remove the condense pipe under the heat exchanger when the pool pump is running but the boiler off. If there is water running out of it, then it is probably leaking.
The fault code gas does not have anything to do with a gas leak or a smell of gas. If there is a smell of gas, then do not use the heater untill it is checked by a Corgi registered engineer. If your boiler has a serial number which starts with 06 or 07 then you should contact Certikin as there is a recall on the gas isolation **** which could be the reason for the smell of gas. Alternatively you can contact ourselves at Kaltech as we are carrying out the recall.
Regards
Karl
sales@kal-tech.co.uk
www.kal-tech.co.uk
Posted on Sep 28, 2008
We have egg smell going though our swimming pool certain times in the day can you help
egg smell ( rotten egg gas ) is hydrogen sulfide
if you have a salt water chlorinator , check the operation for failure
call in a qualified pool maintainer for a proper diagnosis and quote
Jul 08, 2016 | Cars & Trucks
Certikin 11kw pool heater only luke warm, how long does it take to heat a 10ft pool? And will it let out hot water?
water flow too fast bypass with plumbing and only let half or a third go through heater if jumps around and shuts off let more through
May 19, 2015 | Pool & Spa
Water sw open
This shows insufficient water flow through heater, does the water flow look normal at pool or in pump lid? If so it is probably a clog or faulty pressure switch. If not the problem is not the heater.
May 03, 2014 | Rheem 266K to 399K BTU Swimming Pool...
Error code
check gas pressure if too low it will overheat and shut off or run out of gas
Apr 27, 2013 | Hayward Gas Swimming Pool Heater 100k Btu...
Pool heater won't heat water
How big a pool? You normally will not notice a temperature rise immediately. On average, swimming pools will see a one degree rise in temperature every 45 - 90 minutes.
Jan 22, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Heater Wont light
If it has been off for a while you probally just have to bleed the gas line out. Shut off the gas valve at the heater and then open the union at the heater. Turn the gas back on till you can smell gas. Shut it down and close the union then turn the gas back on and try it again.
May 28, 2010 | Rheem 266K to 399K BTU Swimming Pool...
I have a versa gas heater for my above ground swimming pool. This year the pilot will not light. It gets hot but will not ignite. Any ideas what could be wrong?
I have often found spiders or other **** nesting in the pilot tubes of these boilers which blocks the flow of gas. You will either need to have it professionally serviced or you can attempt to do it yourself, which I do not recommend.
Jul 11, 2009 | Raypak Versa 130,000 Btu Above Ground...
Heating & Cooling Logo
1,267 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
