Question about Yorx DM100 Shelf System
Measuring Wow and Flutter
Is it possible that a belt may need to "warm up" before a reliable w&f reading can be obtained? Should there be any difference between a warm or cold belt?
Hi
Thank you for your email today. However, there appears to be some confusion on your side. I did NIOT enquire about finidng"solution for the Yorx DM100 Shelf System ProblemMeasuring Wow and Flutter - pixel.gif" BUT INSTEAD asked "Is it possible that a belt may need to "warm up" before a reliable w&f reading can be obtained? Should there be any difference between a warm or cold belt?" Could this question be addressed, please? Thanks.
Posted on Jul 14, 2008
How to fix flutter & wow on a Gemini 500 XLii direct drive turntable
Direct drive turntables have electronically controlled speed. If the records you are playing are warped (not flat) that will cause wow & flutter. If that's not the problem then you might try connecting the turntable to a different power outlet using a long extension cord. Failing that, the turntable needs repair.
Jul 30, 2014 | Philips gemini XL-500 II Turntable
How to replace capstan belt on Tascam 122?
Rob is essentially correct and I have gotten belts from Consolidated.
If you do not know the size of belts, you can simply order a kit from Marrs Communications and get premium grade Japanese belts. There is more to repairing these than just replacing the belts, there are new idler tires that should be installed and oiling of the bearings and even the reel table rebuild as these get dried out felt in them that develop too much take-up torque. Of course you would need a MTT160 test tape to find this and many local shops do not have them. I do because I worked for Teac before they closed down in Chicago. I was a Lead Technician there in the 80's. I am still working on these even today and have some 122 units in shop now. You are better served to have a Technician do the belts and oiling and all the other stuff that needs to be done such as setting speed and evaluation of the motor by wow and flutter measurement.
May 11, 2014 | Tascam Audio Players & Recorders
Deck is running too slow
The unit either needs a new belt, Capstan bearing oiling as in taking the flywheel out and if this does not fix it a new capstan motor. The motor is adjustable with a small screw driver provided you have the appropriate wow and flutter meter and test tape to do the job.
Apr 22, 2014 | Denon DRM-740 Single Dual Cassette Deck
Telex acc4000xl
The only fault that can be is that the offending machine needs to be serviced and belts and the capstan roller replaced A drop of oil on all bushed cure a lot of these problems
May 18, 2013 | Audio Players & Recorders
Need to know how to replace belts on a Sanyo RD R60 Stereo Cassette deck circa 1987
Well these machines are not always easy to put parts into and there are some things to do that are not written in the manuals even if you get them. Often times the transport has to come out of the unit and then brackets and motor plates have to be removed to access the belts. This is just the reality of the job and why it can take so much time to do it. Just replacing belts in a machine does not guarantee that the unit will work well just from those belts. New belt will allow the torque to be transferred but the speed of the motor still needs to be set and wow and flutter measurements to determine if the deck is usable. Some belts of the wrong type will result in high wow and flutter. It depends on oiling and belt tension and if the reel torques are correct.
The real answer to your question is not how you put the belts in but that you need to have it worked on my a Technician who knows what they are doing. Most deck owners are not set up with experience or equipment to get the correct job done.
Jul 29, 2012 | Audio Players & Recorders
Speed is too slow. Does the belt stretch over time and affect the speed? What else could be the problem
Yes belts do stretch over time, often you will get wow and flutter too with it. Replacing the belt could solve it. If it's old anyway it could do with replacing. Please make a note of how it fits before removing it. Belts are measured in MM (diameter), but with TT belts you need to measure the width.
Jun 27, 2010 | Sony PS-LX250H Turntable
Sony hmk-v82 turn table speed. The speed changes slightly all the time, tone in music goes up and down accordingly. What is the solution?
This is known as wow and flutter. It's generally caused by the belt being lose on a belt drive turntable or the motor on a direct drive one. The motor can cause it too on a belt turntable!
Jan 01, 2010 | Audio Players & Recorders
New crosley CR249-GR "wow and flutter"
I see your message isn't new anymore but Crosley does have a website with warranty and support info:
Crosley Radio
Jul 14, 2009 | Crosley CR248 Turntable
Yorx DM100 Shelf System Logo
110 people viewed this question
Top Yorx Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yorx Audio Player and Recorder Expert? Answer questions, earn points and help others
