Question about HP Officejet 7210 All-In-One InkJet Printer
Carriage Jam I keep getting a carriage jam error and don't know how to fix it.  Can you help?
    Scholar:
  • 162 Answers
Carriage jams that constantly occur are due to something in the path of the paper or a dirty feed roller. I would inspect it very carefully for any type of ware on the rollers or sticky rollers or anything that could interfere with the path of the paper. Could be at one point someone tried to print labels and one got stuck in there and was never cleaned properly.
Another thing could be something broke off and the feed guide is out of alignment.
Posted on Jul 25, 2008
SOURCE: How do I get fix a "carriage jam"?
I was able to run run a piece of photo paper through a couple of times and printer now seems to be working again. The theory was that running a heavy piece of paper through might help clear little piece of paper that was not visible. The photo paper is less likely to tear if it gets jammed too.
Posted on Apr 20, 2008
SOURCE: Carriage Jam error always - how do I fix it?
Try resetting the printer (pressing the cancel button and connecting the power supply, check in the HP website if this is correct for your printer model) , after the reset the printer will clear any errors and will recalibrate the mechanism including the paper feed mechanism and the carriage.
Also check if the carriage is moving freely by disconnecting the power and moving it by hand.
Posted on Feb 04, 2008
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Posted on Apr 27, 2008
Khalsa007
  • 79 Answers
SOURCE: Carriage jam error
Perform a semi-full reset on the all-in-one by following the steps below
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7 Allow the all-in-one to re-initialize. This may take a minute or two.
8 If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information
Thanks
Posted on Jun 04, 2008
rockfixya
  • 679 Answers
SOURCE: error - carriage jam message
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Posted on Feb 03, 2009
Continuous c5280 "carriage jam" error message
If you already followed these instructions, the last thing to do is to service the printer. I don't know of any self-fix options for this printer. It's worth validating that you've already completed these steps as described.
Carriage Jam or Carriage Blocked Message Displays on the All in One
Apr 21, 2014 | HP Photosmart C5280 Printer
I have a HP 5510- it show to have a carriage jam. I don't know how to fix this.
If you get this error message "Open door. Clear carriage jam, and then press OK" then watch this video on how to clear the error (it's in korean but the visual part will help you out):
Feb 11, 2011 | HP Office Equipment & Supplies
I'm getting an error msg and can't print. It says please fix cartridge jam and hit enter. I can't find any jam. What do I do?
If there isn't a cartridge jam then it's probably a carriage jam:
However, I'm not too familiar with clearing a carriage jam. I just know that if your cartridges are not blocked then the carriage is likely at fault. You will need to Google this on how to fix a carriage jam.
Jan 24, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
"carriage jam. Open door. Clear carriage jam, then press okay" error keeps repeating... tried everything still no change...
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
Sep 01, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Carriage jam - Turn machine on, get carriage jam message, however the carriage can move freely if moved by hand. If I close and hit enter, carriage sounds like it's moving, then I get the error message...
Sorry about the B.S., you can move the carriage by hand, and all you need is to clean the encoder strip that runs across behind the carriage assembly. You can wipe the strip gently with an alcohol swab or a Q-tip moist with alcohol. The bars on that strip tell the carriage where it is and grease or ink on it will give the carriage jam error. No calibration necessary after moving the head or cleaning the strip.
Jan 07, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Error message carriage jam and/or paper jam
Often a carriage jam is caused by a paper jam. If you're getting a carriage jam message and a paper jam message, this video should help.
utube.png You-Tube video "wPjahOY5CDo" placeholder
Nov 21, 2009 | HP Photosmart C6380 All-In-One InkJet...
Carriage Jam
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Apr 18, 2008 | HP Photosmart C7180 All-In-One InkJet...
Carriage Jam Error from replacing refilled cartridge
Cleaned the roller & carriage assembly, If possible service the printer your printer will work fine.
Mar 10, 2008 | HP PSC 750 All-In-One InkJet Printer
HP Officejet 7210 All-In-One InkJet Printer Logo
96 people viewed this question
Ben Johnson
