Question about Danby DDR600R Silhouette Dehumidifier
Does not produce water
Hi:
The dehumidifier runs and the compressor sometimes sounds like it is running but does not produce any water. Besides this the RH indicated on the unit is definitely lower than the actual in the room. It displays 30% when I suspect that it is more like 70%.
    Sergeant:
  • 225 Answers
Is there any sign of ice or condensation on the cold pipes? You may be able to see them by removing the filter screen (if present on your model) from behind the inlet grille. There's also a chance that the humidity sensor is clogged with fluff, so fooling the system into thinking the room is pretty dry. A running compressor can usually be detected as a deep throbbing from the machine.
If it is running, but not cooling the pipes, then you may have lost the refrigerant from the system via a leak. If the air coming out of the machine is warm (caused by the compressor running) but there is no water produced this is usually the cause. This is usually beyond the scope of a DIY repair.
Hope this helps. If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills.
If they do not, please hold off on the rating and add a comment with more details so I can try to help you further. Cheers, D
Posted on Jul 13, 2008
Fan runs and the compressor tries to kick on and there is a low grinding sound and then it goes off and the fan continues to run. The cycle repeats itself and the compressor never engages. It is not...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 03, 2011 | Goldstar DH504EL Dehumidifier
LG unit has run great for 4 years and now does not produce any water. Seems to run fine, filter is clean, can hear compressor starting. Just does not dehumitify.????
heatman101
Jul 06, 2011 | LG LHD45EL Dehumidifier
We can hear the fan running and then the compressor, but little to not water produced; sometimes we can hear it click on and then off; the fan seems to be running a lot...
You may have the humidity level set to high. Usually anything above 50%, will show little results, unless your house is flooded.. Turn the humidity setting to the lowest level that your humidifier has
and give that a try.
The fan runs a lot, because it's designed to almost constantly move the air around. That way, if the humidity level rises above the setting on the dehumidifier, it can sense it and the compressor will turn ON.
Hope this helped you. Please let me know. Thanks.
May 17, 2011 | Amana D545M Dehumidifier
Unit run continueously... but produces no water in a humid condition
It sounds like a refrigeration problem possibly a leak in the system or compressor is not kicking on. Either way its probably cheaper to replace the dehumidifier.
May 10, 2011 | Crosley 40-pint Dehumidifier
Dehumidifier makes the room too hot where it is running. does very good removing water need too empty 50 pt every 24-30 hrs.
The dehumidifier does not heat or cool, but the compressor running will produce some heat and it can make a room hotter...
heatman101
Aug 29, 2010 | GE AHG40LJ Dehumidifier
Hi, My Silhouette 63pint dehumidifier does not ...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 21, 2010 | Danby DDR600R Silhouette Dehumidifier
There is no water accumulating in the bottom of my dehumidifier
is the compressor running sounds like its not.
if the compressor is running and no water . unit may need charged.common compressor problems start cap.dissamble to see if compressor in fact is running or not.
Feb 14, 2010 | Kenmore 54351 Dehumidifier
Kenmore dehumidifier runs good but does not collect water.
most likely the compressor is not producing pressures that are needed probably not low on freon .
May 31, 2009 | Eva-Dry EDV300 Dehumidifier
Kenmore dehumidifier runs but won't collect water
If you haven't done so already, try removing and cleaning the inlet filter screen which is almost certainly just behing the inlet grille. It may slide upwards out of the casing or downwards unto the bucket area. If this is blocked with fluff then no moist air will get to the cold pipes, so little or no water will be extracted. There's also a chance that the humidity sensor is clogged with fluff, so fooling the system into thinking the room is pretty dry, in which case the compressor will probably not run.
A running compressor can usually be detected as a deep throbbing from the machine. If it is running, but not cooling the pipes behind the intake grille, then you may have lost the refrigerant from the system via a leak. If the air coming out of the machine is warm (caused by the compressor running) but there is no water produced this may be the cause.
Explore along these lines and let me know what you find.
Cheers, D
Jul 31, 2008 | Dehumidifiers
Danby DDR600R Silhouette Dehumidifier Logo
522 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
