How do I recharge Sunpentown WA-1220M air conditioner?
  • Anonymous Apr 01, 2009
    same problem...
5 Suggested Answers
mattozan
  • 555 Answers
SOURCE: Sunpentown WA-1220M room Air conditioner
Check the hose for a leak.
Posted on Jun 17, 2008
TheMobilian
  • 8220 Answers
SOURCE: Why is my sunpentown WA-1210H portable AC not
Might be a dirty filter, a burnt compressor wire or a bad capacitor. Or it could be a bad thermostat.
Posted on May 10, 2009
daddyo742001
  • 70 Answers
SOURCE: My Sunpentown WA-1220E portable air conditioner is
Sounds like compressor failure, overheat or some other reason can't get started. Make sure everything is clear and unplug and let it set for a while and try again. If that don't help take it to shop.
Posted on Jun 28, 2009
SOURCE: Where could i get a user manual for my sunpentown
http://www.sylvane.com/images/prodphoto/su1872/SF611_Manual.pdf
Posted on Jul 20, 2010
Hi my wa-121oe is not blowing cold anymore
hi.maybe your compressor not working maybe you need charge.
Jul 16, 2014 | Sunpentown WA-1210E Air Conditioner
Ac is working fine on cool then it goes to fan and the air aint cold anymore
Fan mode only moves the air around the Room it will not cool make sure your on a cooling only setting
Jul 03, 2011 | Sunpentown WA-1200E Air Conditioner
Need instruction manual for Sunpentown WA-7500M
You can get the manual on the link below I hop it will help you.
http://www.sylvane.com/images/productpages/sunpentown/manuals/WA-7500M.pdf
Good Luck and please rate 4 thumbs up for the free answer
Jun 19, 2010 | Sunpentown 7500 BTU Portable Air...
Sunpentown WA-1210E
The unit is probably undersized for the space. Rule of thumb is 12000 btu per 500 sq ft. Take a thermometer and measure the entering air to the unit and then hold it in the outlet air stream you should see a temp. difference of about 10 to 15 degrees if it functioning properly. Hope this helps 2rns4u <*{{{>(
Jul 22, 2009 | Sunpentown WA-1210E Air Conditioner
My Sunpentown WA-1210E airconditioner stopped working. It emitted several beeps and the power light is blinking continuously. When I unplug, wait a few minutes and replug in the unit, it shows the same...
Have you checked the water container in the unit? It has a float switch that when it is full it will not allow the unit to run so that it will avoid spilling water on to the floor. Hope this helps 2rns4u <*{{{>(
Jun 29, 2009 | Sunpentown WA-1210E Air Conditioner
My Sunpentown WA-1220E portable air conditioner is not working. Comp light is flashing (red light). Any idea what could be wrong?
Jun 28, 2009 | Sunpentown WA-1220E Portable Air...
Air conditioner
filters blocked or fan cage full of dust cant pickup the air if this is a zoned system then maybe zone damper is stuck not letting the air through
Jun 20, 2009 | Sunpentown WA-1210E Air Conditioner
Why is my sunpentown WA-1210H portable AC not blowing cold air anymore?
May 10, 2009 | Sunpentown WA-1220E Portable Air...
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
