Question about Kodak EasyShare Z710 Digital Camera
Lithium crv3 3v battery and charger and usb cord need to purchase.
I need to find out how to purchase the camera lithium crv3 battery and battery charger and the usb cord for my z710 camera ?
  • Anonymous Mar 21, 2014
    is crv3 lithium the best option
    Genius:
  • 2,985 Answers
Google is a good place to look
Posted on Jul 21, 2008
I have the vivatar vivicam8025, how do you recharge it with the cable, I can't find the manual
Charge lithium battery
A. Charge with USB cable
Insert the lithium battery into your camera correctly, and connect your camera to computer with USB cable. The red LED of camera will be light on indicating that your camera is in charging status, the LED will be off when charge full.
B. Charge with supplied charger
Your camera is supplied a compatible charger for you, you are only required to put the battery into charger and charge the lithium battery directly from electrical outlet
http://www.vivitar.com/files_products/13/VC8025%20User%20Manual.pdf
Mar 02, 2011 | Vivitar ViviCam 8025 Digital Camera
Vupoint dv-dv1-vp camcorder needs a new battery
Buy a "np-60" battery on ebay or other store. Some will come with a charger.
You can charge the battery via the usb cable from any working usb port.
Mar 19, 2008 | VuPoint DV-DV1-VP Camcorder
I need to know what the charger looks like. does it take batterys? where do they go? how do I charge the camara?
You can purchase a charger for this camera at http://www.amazon.com/Wall-Charger-Adapter-Vivitar-Vivicam/dp/B003M6BXBO/ref=pd_sim_e_1
Feb 28, 2011 | Vivitar ViviCam 8025 Digital Camera
Can you charge camera from USB?
You don't say what make or model the camera is, so I can only answer generally. Most cameras, as opposed to most cellphones, do not charge the battery in the camera at all. They are supplied with a separate mains charger- you take the battery out of the camera and put it in the charger. I have a number of cameras with USB connectors, and none of them charge while connected to the computer.
If you bought the camera new, and it came with a charger, then the camera almost certainly needs the charger to charge the battery. If you purchased it used or it was a hand-me-down, and you didn't get a charger, then the seller or giver has probably been remiss. It won't hurt to leave the camera connected to the computer's USB port to see if it will charge, but when that doesn't work, you can find a replacement charger for your camera by searching Amazon with the camera model number and the word "charger". Better, you can get a "universal" charger on Amazon for as little as $4 that will charge any of the small lithium batteries used in cameras and phones (assuming this isn't a huge battery of the kind fitted to older video cameras). I have a universal charger and it is easy to use and has saved me a lot of money as I no longer need to buy a replacement for every type of battery I come across.
Jan 02, 2011 | Vivitar Cameras
Re: Battery Charger BC-45W I just purchased a Fuji JZ500 and the battery needed to be charged. When I plugged the charger into the power outlet, the indicator light (yellow) turned on but after a few...
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Dec 23, 2010 | FUJIFILM BC45W Rapid Travel Battery...
The manual says "your camera comes with a compatible charger, your only required to put the battery into the charger and charge the lithium battery directly from the outlet" The camera came with an AC...
You put the battery into the camera. Put the USB end from your computer cord into the end of the AC adapter hook it up to your camera. Ta-da! Everything should be working smoothly in the battery/charger department. :)
Dec 26, 2009 | Vivitar ViviCam 8025 Digital Camera
Can u charge camera with usb cable from computer
The Kodak camera that I own states in the manual that you can charge the batteries only with the printer/dock or separate battery charger. I've left mine plugged into USB for hours at a time and never noticed a charge going into the battery. I use both AA lithium-ion batteries and the pack that came with the camera. The Li-on AAs work as well as the pack and for a cheap price, I purchased 4 AA and the charger (about $15).
Nov 28, 2009 | Kodak Easyshare M753 Digital Camera
Lost battery charger and usb cord. How much do they cost?
https://emporium.olympus.com/innards/emp.asp?val100=100&step1=1361&step2=0
Here is the link to the Olympus store where you can purchase the battery charger and the USB cable for the camera.
Apr 12, 2009 | Olympus Stylus 1010 Digital Camera
Vivicam 5340s camera dock
You can't charge the camera with the USB cord because the camera dosn't have a charger built inside. You need to use an external charger. Here is a link showing several sites that have battery chargers for this camera.
Dec 26, 2008 | Vivitar ViviCam 5340s Digital Camera
Power cord HELP
Power cord is almost impossible to find! However, you can purchase a charger for the lithium battery itself!! Good luck
Oct 30, 2007 | Samsung SC-D372 Camcorder
Kodak EasyShare Z710 Digital Camera Logo
129 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
