Question about RCA HDLP50W151 50" Rear Projection HDTV
Color blinkig in and out.
I have a RCA 50 inch dlp tv (m50wh72syx12).It was about a year after i baught it i had to replace my lamp,that was about 4 months ago,now randomly the color will fade to a light green color real fast then go back to normal.It seems to have started happening more as time goes on.
  • 1 more comment
  • cecildelavan Jul 18, 2008
    I checked and i don't hear a humming noise and the fans seem to be running,thanks for the info.
  • storme2000 Nov 05, 2008
    I have mine for about a year and a half. After about 45 minutes the picture goes from normal to a rapidly-flashing green and sometimes becomes pixelated during these outbursts. If I turn it off for about 15 minutes or so it comes back on, reluctantly, turning first reddish, then green and then will perform normally for another 45 minutes. I don't hear anything abnormal. Not sure about the fans but I would say this might be heat related. Does anybody know if this has something to do with the bulb or is it something much worse and how much would it be to fix?
  • Anonymous Jan 30, 2009
    I have had my t.v about 1.5 years, and I had the same problems. I had the t.v. serviced and was told it was the optive lense, which is the main part of the t.v.
  • 2,334 Answers
It seems like the color wheel might start to fail.
Do you hear any abnormal sound(s) from the TV when ramdon color appears.
Would you be able to check and make sure all the fans are working properly?
Posted on Jul 16, 2008
Samsung dlp HL-R5067W sound no picture
Check for open or leaky capacitors look for bulge on the top of caps
Mar 28, 2014 | Samsung Hl-r5067w 50-inch Hd-ready Dlp Tv
I have an RCA M50WH72syx12, 50" DLP.
Yeah could be expensive if it isn't the lamp.
Mind you could be a little easier, might just be a fuse on the video relay. If you are confident in being able to open it up, check the relay that runs from the video input to the power capacitors and there should be a small fuse along that circuit.
If the fuse has a broken capsule then you may just be in luck. Failing finding a broken fuse, then I would agree with you on the bulb. But check the blub for any markings or cracks because they usually only make noise when the vacuum fails.
Hope this helps and good luck mate! :D
Nov 23, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
RCA Model M50WH187 DLP TV - lamp cuts out
The lamp ballast supplies power for the lamp, and it is probably going out. You can probably find one on eBay or ShopJimmy for under $100. It looks like a little box and it will be near the lamp.
May 01, 2017 | RCA Scenium M50WH187 50" HDTV
50 inch rca dlp tv. new bulb. makes a loud
Color Wheel needs to be replaced. Call PartStore.com
1-866-925-7278 For Part number go to Encompass Parts Distribution they will list part number.
Apr 28, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
I have a 50 inch RCA Real Projection TV (DLP or HDTV). I just replaced the lamp and everything worked fine. One night it made a big sound and shut off. Now when you turn it on, nothing appears, a few...
you could have a color wheel problem or a power supply problem
one questions did you reinstal the door at the rear
you might want to remove the lamp module and try a reinstal and see if condition changes
as to costs if you can get the color wheel 150.00 or so
there ae several things that could cause this a dmd module a color wheel and power supply or digital board the lamp cover when installed it closes a saftey switch there thats why i ask if you has installed door
Oct 22, 2009 | RCA HD50LPW175 50" HDTV
Model #m50wh72syx12.... sound but no picture...
I have the same problem, TV is only 3 years old. Already replace bulb once and helped for a little while. The more I check, this sounds like a very common problem. Hmm...maybe a class action suit?
Sep 28, 2009 | RCA Televison & Video
My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
Mar 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
RCA 50" dlp lamp dead?
There are many different problems with RCA televisions. One could be a color wheel. Another could be a bad ballast. www.Lamp-Replacement.com has a guide and solutions for your RCA lamp 265866 or 270414. The problem is most likely a bad ballast, which is supposed to pre-charge your lamp and ignite it. If you aren't even getting to that stage, you can trace the problem to another component or power supply.
Sep 01, 2007 | Televison & Video
RCA HDLP50W151 50" Rear Projection HDTV Logo
204 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
