Question about Epson TM-U220 Matrix Printer
TM -U22O PRINTER
PRINTER WANT FEED AND AUTO CUT ANY SUGGESTIONS
  • robertmicros Apr 03, 2009
    printer powers on but just makes acllicking sound, won't reset,feed or print.
The send command is:
0x1d "V" 0x41 0x00
Posted on Mar 04, 2009
Install the correct driver
Posted on Oct 25, 2008
Send ESC/POS Secuences
Posted on Aug 28, 2008
When i print the test page on my epson TM-T88IV it displays the "paper out" error when the paper is there. What could be the problem? Please help because they are two of them doing the same.
Try to take out paper roll and try reinstalling it, make sure cover is closed properly as well.
If same issue persist, call your dealer or Epson for Authorized Service Centers. Or you may Visit their website at www.support.epson.com
Hope this helps.
Feb 16, 2011 | Epson TM T88 Thermal Printer
TM-T88III print speeds and other issues
Try setting both switch 1-7 and 1-8 to ON for 38400 baud, set switch 1-2 to OFF to give a 4k buffer, set switch 2-5 to OFF to release the busy buffer at 256 bytes, set switches 2-3 and 2-4 to ON & OFF for medium print density and OFF & ON for dark print density or OFF & OFF for normal print density.
Also remember that the thermal TM-T88III also prints faster when the print head is cooler and slower when it heats up. The print speed is adjusted automatically depending on the voltage applied and head temperature. So make sure your power supply is providing a steady 24VDC at full load and has enough capacity to provide a peak of 7.7A in full speed mode. If you are using the printer in high temp and humidity you might want to swap the unit out for a Star Printer which performs faster and uses the same protocol or use a cooling fan.
Also make sure you use a good quality paper and that the humidity is within range at 10 – 90% RH although the paper performance will be greatly diminished at higher humidity levels.
Specifications:
High-speed = Approx. 150 mm/s {5.9"/s} max.; 47.2 lps, max. (3.18 mm {1/8"} feed);
35.5 lps, max. (4.23 mm {1/6"} feed, at 24 V, 28°C {82°F}, density level 1).
Low-power: Approx. 16.5 lps (4.23 mm feed {1/6"}); 70 mm/s {2.76"/s}
Ladder bar code: Approx. 42 mm/s {approx. 1.7"/s}
High-speed mode: Mean: Approx. 1.8A Peak: Approximately 7.7A @24VDC
Low-power mode: Mean: Approx. 1.2A Peak: Approximately 6.6A @ 24VDC
Operating temp = 5 to 45°C {41 to 113°F}
Operating Humidity = 10% - 90% RH
Aug 28, 2009 | Epson TM-T88III Thermal Printer
I have a TM u220 printer. I can't get it to auto cut. Any ideas? Is there a code?
TM 220a and TM 220b should come with auto cutters
You have to unscrew the metal tab under the printer, you will find two sets of DIP switches. upper one is DWS 1 and the lower one is DWS 2. On DWS 2 you need to have jumper #2 ON. this enables or activates the auto cutter on printers. Good luck...
m
Jun 29, 2009 | Epson TM-U220 Matrix Printer
Auto cutter does not cut automatically
Jun 08, 2009 | Epson TM-U220 Matrix Printer
User Intervention required on Epson TM-U220PD
I had the same problem with the user intervention required status on the printer. I tries reinstalling it several times through the Epson Driver Utility but got the same message each time. I got it to work after making two change but do not know which one (if either) got it to work. First i uninstalled the printer driver through Add/Remove Programs and not through the Driver Utility. I also set Dip switch 1-1 to on which enables auto line feed with parallel interface, with other interfaces this switch changes other things.
Dec 02, 2008 | Epson TM-U220PD Matrix Printer
Problem setting up TM-U220
print the self-test, push the feed botton while powering on...
you can see there the serial interface...
baud rate, data bits, parity, stop bit etc...
then go to the printer and faxes,
right click the epson driver and click properties...
go to the ports window...
click on the epson tm u220 reciept.
click configure port...
adjust the baud rate as same as in the self test...
it works...
May 22, 2008 | Epson TM-U220 Matrix Printer
EPSON TM T88IV
The TM-T88IV printer is a thermal printer and does not have ink or a ribbon.
If the printer is not printing you may have the wrong type of paper in the printer. You must have thermal paper in order for the printer to work. Paper for a dot matrix printer will not work in this printer.
The printer has a self-test that you can perform by turning the printer off, holding down the Feed button and turning the printer on. A test strip will print. Press the Feed button again to print a longer test strip.
May 14, 2008 | Epson Stylus C66 Photo InkJet Printer
TM-U220 printer is not printing anything.
do a self-test first. Perform by holding down the feed button then powering on the printer. if it prints then it is not a printer issue, but a driver or cable issue.
May 09, 2008 | Epson TM-U220 Matrix Printer
Unfinished printing cut-off
Are you using the APD304e driver for your printer? It has option where to cut paper, if not you can download driver from epsonexpert.com site, you will have to register first so that you will get a username and password. then go to technical resources, then select printer model then download driver
May 01, 2008 | Epson TM T88 Thermal Printer
How to auto tear paper after printing receipt is completed.
moz-screenshot-2.jpgIf you are using the generic driver you can get the code from epsonexpert.com site or try this
SELECT CUT MODE AND CUT PAPER ASCII GS V m
executes full or partial cut. HEX 1D 56 m
DEC 29 86 m
m = 0, 1, 48 or 49 cuts paper
SELECT CUT MODE AND CUT PAPER ASCII GS V m n
feeds paper and executes full or partial cut. HEX 1D 56 m n
DEC 29 86 m n
m = 65 or 66 feeds paper to (cut position + [n x (vertical motion unit)]) and cuts the paper
n = 0 to 255
8f9f602.tif
Apr 08, 2008 | Epson TM-T88III Thermal Printer
Epson TM-U220 Matrix Printer Logo
713 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
