Question about DeLonghi DCM485 Coffee Maker
DeLonghi DCM485 Coffee Maker Won't Brew
When I press the on button the coffee maker lights up, but does not brew. I have tried resetting the machine, but that has not helped.
2 Suggested Answers
SOURCE: My DeLonghi DCM485 coffee maker
The same thing happened to me....At least you got three years out of yours, I got three months.
Posted on Sep 11, 2008
Lite is on will not brew there is water and coffee and it doesnt brew
You can try this.
1. Plug the coffee maker into the wall power outlet. Turn the switch on. The light will glow. Then press the on/off switch TWICE. The coffee maker will start.
2. If the machine doesn
Aug 02, 2011 | DeLonghi DCM485 Coffee Maker
How do I program my DeLonghi DCM 485?
Hi and welcome to FixYa, I am Kelly
First you must set the clock. Page 6 of this pdf manual:
http://www.smallappliance.com/images/SmallAppliance/English/products/standard/DCM485.pdf
Then prgram per instructions at the bottom of page 6 and the top of page 7 of the same manual. I note step 2 is missing from the manual.....
3. Press the CLOCK button until the desired brewing time is displayed
(See "How to Set the Clock" section of the manual).
4. Press the ON/OFF button to confirm the automatic time selected.
NOTE: The display panel and the on/off indicator light will flash.
5. Press the PROGRAM button to return to the current time of day (the
ON/OFF button will continue to flash.) The brewing cycle will begin
once the set time is reached and the ON/OFF button stops flashing.
6. If you want to check the automatic time selected, press the
PROGRAM button.
7. To override the automatic brew function, press the ON/OFF button
and the coffee maker will start immediately. Press the ON/OFF
button again to switch the coffee maker off.
Thanks for choosing FixYa,
Kelly
May 21, 2011 | DeLonghi DCM485 Coffee Maker
My DeLonghi DCM485 coffee maker will not brew coffee. Cannot find any troubleshooting to solve it. Help
Aug 09, 2008 | DeLonghi DCM485 Coffee Maker
Light is on but coffee won't brew.
Patti, you probably have a thermal fuse blown.
May 02, 2008 | DeLonghi DCM485 Coffee Maker
Display illuminates - but no display of time, etc.
My coffee maker is a Signature Classic and when I turn it on the light turns on but nothing happens. The water doesn't steam and the hot plate under my coffee pot doesn't heat up either, what's wrong I need my coffee?
Mar 24, 2008 | DeLonghi DCM485 Coffee Maker
Won't brew
Yosemitesam, tomorrow I will ask this for an expert here in Mexico, when I knew the problem i will let you Know..
Jan 02, 2008 | DeLonghi DCM485 Coffee Maker
Won't brew
bring white vinegar to a boil and pour it into the perforated top, the water reservoir and the link between the water reservoir and the brew basket. let sit a few minutes, pour it out and do it again.
put the water reservoir back in, put water and vinegar solution ( half and half) in. Try to start it again. Mine did this last year and this fixed it right away. Try to clean the coffee maker using the vinegar solution once a month to avoid this problem.
Sep 13, 2007 | DeLonghi DCM485 Coffee Maker
Resetting........won't brew
Have you unplugged it? Sometimes unplugging and waiting a day or so resets the computer inside the unit.
Aug 25, 2007 | DeLonghi DCM485 Coffee Maker
Delonghi dcm 485 power on but will not brew
THANKS "Guest" - you just saved me $100 !
I had already bought a new coffee maker (Krups) when I came across your post.  The thermal fuses (there are two of them) are indeed hidden - they are right underneath the metal braces/clamps that push them against the heating element that they are meant to monitor.  If you take off these clamps and pull back the white insulation you can easily replace the fuse(s).  What you need is:
- volt meter
- needle-nose pliers
- Radio Shack thermal fuse 228C (catalog #270-1321) - these are rated at the same temperature and look fairly identical.  They cost $1.69 at your local Radio Shack
You do NOT need a soldering iron.  So: - take off the bottom of the coffee maker - take off the clamp(s) and pull back insulation. - put your volt meter on either side of the fuse and check for continuity.  In my case, one had no resistance (good) and the other had no connection (bad). - take your needle nose and pry open the clips on the end of the wires that connect to the bad fuse ... put in the new fuse (make sure the polarity matches ... just in case) and scrunch the clips together again - replace everything
In order to make this easy to do, I disconnected the water intake/outtake and also removed the two screws holding the whole heating assembly.  Made it a lot easier
Aug 19, 2007 | DeLonghi DCM485 Coffee Maker
DeLonghi DCM485 Coffee Maker Logo
329 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
