No it does not reboot with or with out recovery disc it still comes up error in big red letters with the reboot disc and without the disc it just says media test failure check cable etc help me plzzzzzzzz ty
Sounds like your hard drive has crashed. You will need to replace it.
You can try to run the Check Disk Utility to see if it can repair the drive.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
*** Remove any external monitor as it will make entry into BIOS utility and recovery process difficult. ***
The following is from pages 29-30 of the 52-page D250 UserGuide.pdf located in folder C:\Book
I want to restore my computer to its original settings without recovery CDs.
This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1. Check to see if Acer disk-to-disk recovery is enabled or not.
2. Make sure the D2D Recovery setting in Main is Enabled.
3. Exit the BIOS utility and save changes. The system will reboot.
Note: To activate the BIOS utility, press during POST (Power On Self Test).
To start the recovery process:
1. Restart the system.
2. While the Acer logo is showing, press + at the same time to enter recovery process.
3. Refer to the onscreen instructions to perform system recovery.
Important! This feature occupies 6 GB in a hidden partition on your hard disk.
Some times with this make you can press alt and f12 at startup , just before it comes to the loading windows page, some of these laptops have a recovery partition, so hope this helps
Unfortunately , you are going to have to call Toshiba.
from the sound of it your recovery disks are failing and they have already formatted your harddrve
rebooting a laptop means turning it off then on again not to it's original state, your are using a recovery disc which will reformat your drive the reinstall windows, loosing any documents or files you have saved.
The serial or product key code for windows is always on the underside of the laptop
Can you reboot and get into windows or is now corrupt?
What do you mean by 'uninstalled XP'??
You cant uninstall it unless you format the drive, in which case the recovery discs are now probably useless as they rely on a folder on the HDD called i386.
Recovery discs normally dont have the OS on them, they rely on the I386 folder to gather info about the computer and then restores it to the state when it was new.
If you can acess the system, reboot and go into the bios and change the boot sequence to CD, then insert the first recovery disc. then save the settings and the computer will reboot and start the recovery process again, this should clear up the error.
If it does not it will be because the i386 folder is missing in which case you can either explore the recovery discs for it or you will have to buy a copy of Windows XP.
