Question about Belkin Computers & Internet
I have (stupidly) disabled the NAT feature of my Belkin wireless G router, without specifying an IP address to access it, and so can get no access to the wireless network from any pc. Is there a way to enter the router to re-set it or correct the problem. Because it won't recognise me I cannot access it using the normal ip in the browser. Cheers!
  • GSXRSEVEN Jul 13, 2008
    After trying the above and it not working I read that if you unplug the router and hold the reset for 20 seconds whilst re-powering it should reset and after this I followed the instructions and all is well.
    Thank you Spin!!!
    Scholar:
  • 62 Answers
To turn the NAT feature back on in the belkin router, just reset it.
And you can always tell what address (known as the gateway address) access the router, which ip,
by clicking start, run, and then type cmd and click 'OK'
in the black window that pops up, type 'ipconfig' without the commas and hit enter on your keyboard
look for the default gateway
if nat was on, or after you reset it,
its 192.168.2.1
type 192.168.2.1 in the address bar of internet explorer to access the router
most routers default password is ither admin , or password
spin
Posted on Jul 13, 2008
I have a belkin g+ mimo router and am currently trying to set it up as an access point to interact with my d-link dir-615 router. when i add my d-link routers ip address string, the belkin disappears. i...
Hello...
Steps To Convert your Belkin Router as an Access Point.
- Connect your D - Link Router to your PC & Check the Default Gateway It Might Be 192.168.1.1 or 192.168.0.1
( Finding Default Gateway: Right Click on Local Area Connection & click on Status - Click on Details For Win 7 & Win Vista & For Win Xp - Right Click on Local Area Connection & Click on Status, Select Support Tab & Click on Details )
- Now Connect the Belkin router to your Com .. Open Internet Browser & Go to 192.168.2.1
- Towards your Left Corner Under Wireless Clink on Use as Access Point
- It will Prompt you For a Password Leave it Blank & Click on Submit
- Select the Radio Button Next to Enable
- In Specify IP Address Type in IP Address in Range of your D - Link Router Eg: 192.168.0.254
- Select Subnet Mask - 255.255.255.0
- Click on Apply Changes
- Now Open the Router Setup Page Using the Ip Address which you gave EG: 192.168.0.254
- Connect an Ethernet cable From your D - Link Router to Any 1 of the Wired Slots on the Router ( Note: We are using Wired Slot as we have Disabled the NAT on the Belkin Router It Gives you IP Address From your D - Link Router & the DHCP on the Belkin Router is Turned Off)
- Power cycle the D- Link Router & Belkin Router For 15 Seconds Each ( Unplug the Power cable & Plug it Back After 15 Seconds)
- Now go to the Router Setup Page & Check the Internet Status in the Top Right Corner It Would Be Connected.
- Try Going Online... :)
Feb 19, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I disabled the nat on my wireless router and now i can no longer access the router setup page by typing the ip address in the address bar
That is because your router essentially no longer has an IP address. If you need to access your router configuration, you will need to re-enable NAT, which means factory reseting the device. There should be a recessed reset button on the router, most likely on the back. Hope this helped.
Dec 12, 2010 | Belkin My Essential (ME1004-R) Wireless...
On Modern Warfare 2 I have a STRICT N.A.T type. How do I fix this on a BELKIN F5D8232-4?
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Oct 09, 2010 | Belkin N1 Vision Wireless-N Wireless...
Need to change my nat setting from strict to open can't find anywhere on belkin wireless router settings
Step 15:Enable UPnP
Goto : my blog for more information about belkin routers (Page is still under construction )
Jun 23, 2010 | Belkin Wireless-N Wireless Router with...
Cant connect 2 wireless
At any cost do not disable the NAT - because thisis the feature which allows multiple device to work with router
So only option you've got now is to reset the router. It should be at the rear end of the router. Hold onto it for 30 seconds, u'll see the light flash and router reboot
Once you've done with that - configure router and make it work.
And as of for the Xbox Issue try these steps:
1 - Assign a Static IP address in the Xbox:
- Go To Network Settings - Configure Network
- Change IP settings to Manual
- IP Address: 192.168.2.45 Subnet Mask: 255.255.255.0 Gateway: 192.168.2.1
- DNS settings to Manual
- Primary DNS: 192.168.2.1 Secondary DNS: 4.2.2.2
2 - with any of the Wired Computers
- open IE - type - 192.168.2.1 - u'll get the Router Interface
- left hand side in the list of options
- click Firewall - leave password blank - disable and apply changes
- click Virtual Servers;
- under enable place a checkmark
- description : Xbox, Inbound Pot : 80(if there are two boxes here duplicate in both the boxes), Type: TCP, Private IP: 45, Private Port: 80
- So Similarly fill up the table for these following Ports
TCP: 80, UDP: 88 Both(TCP&UDP): 53, 3074
Additional Note:
If u've a DSL connection, call ur ISP and make sure ur modem is bridged and the NAT is disabled
Dec 22, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin g plus mimo nat problem
Step 1 : Check the IP Addressof the Xbox And take a note of it
Step 2 : Open RSP By typing 192.168.2.1 on the Address bar of the internet explorer
Step 3 : On the left side Click Firewall
Step 4 : Leave the Password blank and click Submit
Step 5 : Disable it And Apply Changes
Step 6 : On the left side Under Firewall Click DMZ
Step 7 : Add the IP Address of the XboX in DMZ
Step 8 : Click Apply Changes
Step 9 : Restart the Router
Step 10 : Test the Connection
Apr 12, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
We've just moved house and have aquired to belking routers a belkin wireless pre n and a belkin ADSL G Plus MIMO I want to use the latter as a bridge how can I?
You need to access the setup page of your Belking router and go to the wireless setup, look fro Use as Access Point, now just a reminder this will defeat the NAT IP sharing feature of the router. Configure the IP address of the router to the same subnet as the network your tying to bridge here's the more detailed procedure:
1. Enable the AP mode by selecting "Enable" in the Use Access Point only page. When you select this option you can now change the IP Settings.
2. Set your IP settings to match your network. Click "Apply Changes"
3. Connect a cable from the LAN port of the router to your existing network.
Sep 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless connection problem
Internet Setup
Internet Connection Type: Obtain an IP automatically
Host Name: linksys
Domain Name:
MTU: Enable Disabled
Speed & Duplex: 10 Mb Half
Local IP Address: 192.168.1.1
Local DHCP Server: Enabled
Start IP Address: 192.168.1.
Number of Address: 50
DHCP Address Range: 192.168.1.100 ~ 149
Client Lease Time: 0 (0 means two day)
Static DNS 1:
Static DNS 2:
Static DNS 3:
WINS:
DDNS: Disabled
NAT: Enabled
Dynamic Routing: Disabled
Wireless: Enabled
Wireless Network Name(SSID): linksys
Wireless Channel: 6 - 2.442 GHZ7
Wireless SSID Broadcast: Enabled
Wireless Security: Disabled
Feb 23, 2008 | Dell Inspiron 1200 Notebook
Strict NAT
Ok this is how its done. Open your DMZ on your router interface click enable. The IP address you'll have to enter the last digit. This IP address digit is found on your xbox, look under your xbox network setting an get the last digit of IP address an this will only set your xbox to open. bang thats how u fix it. Very simple. any Q's am @ murdock_theory@yahoo.com
Nov 30, 2007 | Belkin (F5D8231-4) Wireless Router...
Computers & Internet Logo
93 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
