Question about Karcher 2500 PSI Pressure Washer
Kracher k3 97, low pressure
The motor runs and cuts out as it sould befor the trigger is pulled, but when the trigger is pulled there is flow but no pressure the motor cuts in ok, i have checked the inlet filter, please help.
  • 33 Answers
Your pressure relief valve is stuck open. try adjusting the nut shaped stem on the front of the valve to see if you can unstick it. if not you'll have to take apart and clean.
Posted on Apr 21, 2009
Motor runs fine until I pull the trigger for the pressure then it kills the engine like its in a bind.
blocked main jet or fuel flow problem until you pull the trigger there is no pressure in the pump pulling the trigger makes the pump work and the motor is not responding possibly from a carby fault
Dec 19, 2017 | Garden
My Karcher 530M runs ok until I release the trigger, then it will not start again unless I switch and allow the water to run through for about 15 secs before switching on again
Hi Cliff:
My experience is that the pump pressures prevent the engine from starting, so we hold the trigger while starting.
My brother has cut a wedge of wood that he uses to jam the trigger open to bypass the problem. It can get a bit wild if the wand is not secured when the unit is started..
Aug 10, 2016 | Karcher Garden
I switch the pressure washer on motor starts pressure builds up motor stops. OK pull the trigger on the lance the moter starts sounds different water pressure low. Release trigger motor still runs.
It isnt very clear your explanation of the problem but what type washer do you have first? It sounds like you have a bad unloader or need a new variable nozzle tip. Can you explain in more clear detail. Thanks
Feb 16, 2015 | Garden
Pressure washer runs about 10 minutes then cuts off
Could be low oil. Most motor turn off as a protection when the motor oil is low. Also, recently I have a similar problem, with a easy solution, just don't push the accelerator nob all the way, leave a 1/4 before reach full power. Apparently some times there is a bad calibration an make the carburetor over flow.
Sep 16, 2014 | Craftsman 2700 PSI Briggs Stratton...
Pump will not unload.
Hi if it stop when the trigger is pulled the issue is with the motor.
stopping is caused by , low revs on motor or low compression or poor spark, sometimes faulty carby.
change spark plug , adjust valve ( when valve has some slight side movment it is ok if up and down , it should be tighter (valves usually under side cover near top ) increase revs a little ( make sure revs dont get rough when running high) set max revs to when the engine still runs smoothly at max.
Mar 30, 2014 | Delta Model DT2400CS Pressure Washer 5.5HP
Kracher power washer won't turn on
Sure that the outlet you are using is powered? Is power reaching the motor? - I had my power switch on my karcher break internally rendering machine dead. If power is reaching the motor for sure and it does not run then there has to be an open motor winding. If pump jammed you would hear a humming noise from motor and the breaker would pop.
Aug 26, 2017 | Washing Machines
When trigger is pulled pressure goes up and down as long as trigger is held
When you start the pressure washer, having the water from the faucet at full pressure, apply pressure to the triger gently....this should allow the system to release the pressure gradually and keep up.....when you pull the trigger full throttle, it can cause the jurking sensation in system. If this does not resolve the problem you may have a bad empeller pump and requires replacement. Do not allow the pressure washer to run for more than a couple of minutes without water flowing thru is as this will burn up the motor )empeller pump). Good luck
Feb 11, 2011 | Garden
Spectrum 2050 plasma cutter . Cutter blows air and stops when trigger is pulled no pilot arc or any cutting when trig is released air flows again and stop after 10 sec new tips was working the day...
Check compressed air pressure is in limits otherwise unit will cut out. Try adjusting the pressure up. also make sure the supply pressure is correct as it may not be your plasma cutter at fault.
Jul 30, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
Karcher K2.36 motor cut out and won't restart
Yes, the water should be turned on first but if it only ran for a minute or two it should be OK. Most late model pressure washers have an automatic shutoff when the trigger on the wand is released. Turn on the water and then the machine and then squeeze the trigger on the handle of the wand and the motor should start as soon as the air is cleared from the line by the flowing water (about 10 seconds). If the unit was put away wet last season you may need to clean the nozzle with a piece of wire too.
Apr 16, 2010 | Karcher Garden
Pressure Washer Engine will not stay running
My Kracher 2500 pressure washer has no pressure unless I remove the nozzle. If, I remove the nozzle and pump the trigger several times and quickly replace the nozzle it works fine until I release the trigger. Karcher (online) suggested I remove and clean the unloader which I did. It still doesn't work correctly. What another solution?
May 29, 2009 | Garden
Karcher 2500 PSI Pressure Washer Logo
733 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
