Question about Samsung SGH-t629 Cellular Phone
Problem my problem is when i insert memory card in my phone.it is not detecting memory.if i click on memory then it is showing unrecognized format.what do i do.i did not asked my any format to do
Contact the memory card company. I had san disk and even though it was alot of work to get a new one for free, in the end it was worth it. good luck.
Posted on Jul 29, 2008
In Phone show error "memory card corrupted" &
1) Insert your card in the mmc reader.
2) Find the drive in which it is inserted from your pc.
3) Right click the selected drive and select FORMAT but NOT quick format.
4) Now, in the file system selection part, select the file system to be FAT and not FAT 32 or NTFS file system.
5) Start formatting.
Nov 03, 2011 | Nokia 7610
My motorola w490's problem is it cannot read my memory card,it always says that (inserted memory card:unformatted)
The problem is that your card is not formatted well..Try to format it by connecting to a computer either by phone or by card reader..
now right click the memory card drive and select the format option on the tab.
after the completion of format remove it form computer and insert it on your mobile..
now it will detect your memory card..
i request you to kindly rate me on fixya if i am helpful..
Dec 18, 2010 | Motorola Mobility W490 Cellular Phone
My new sanyo camera will not format my memory card it says do not turn power off so i leave it on and the camera turns off itself but the memory card still does not format. Can you help?
Presuming that after trying out to format the memory card is not working out I would request you to please remove the memory card then either using an holder if required connect to your laptop or the PC. Most of the present day computers have the slot for the memory card. As you insert into the computer it will show detection, if not reinsert. Once it is detected, click on the memory device detected in the my computer window , right click for foramt and do so. If the memeor card is not detected or if files are not opening then take a search on the device and open. Delete or format as requried. I hope this help you out. Good day
Jun 23, 2010 | Sanyo Xacti VPC-T700 Digital Camera
My phone can't read the memory card.it gives me this message (memory card has an unrecognised format. Reformattingvwill erase all data.
If the memory card worked before with your phone, then suddenly became unrecognized, then the memory card probably got corrupted.
The best thing that you may try is to insert the card to another phone and connect it to a different computer. There are times that another computer recognizes the card with this kind of problem.
If a different computer recognizes your card, immediately back-up the files, then reformat your memory card. However, if the same problem occur on different computer, then there's nothing that we could do but to reformat it.
Whether you reformat it or not, you could no longer recover the files if it's still unrecognized.
Thank you and good luck!
Jun 25, 2010 | Computers & Internet
I did a reformat but still my phone cannot detect the memory card
1. If your memory card can be detected on your computer, then try to completely format the card.
2. Goto Start >> My Computer >> Right-Click the memory card icon >> Format >> Uncheck the Quick Format option >>
Start >> OK / Yes (confirm the request!).
3. If the memory card cannot be detected / readed by your PC, phone, or camera, then that card has become corrupt / unrepairable!
4. You should replace that memory card with a compatible one!
please rate this advice if it helps...tc! :)
Sep 24, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Memory card not detected
your card is automatically locked and it is only unlock by using memory card unlocker device but it also format your mmc.other than this you have no choice to open memory card.yes you can use recovery software for recover your important files
Jul 30, 2009 | Electronics - Others
NOKIA 6600 HAVING PROBLEM INSERT MEMERY CARD
IF U HAVE THE CELLPHONE DRIVERS OF YOUR PHONE AND U GOT A COMPUTER AND THE CABLES FOR THE PHONE PLUG IT INTO YOUR COMPUTER IT WILL TELL U IT HAS DETECTED YOUR PHONE OPEN IT AND RIGHT CLICK ON THE DRIVE OF THE PHONE CARD MEMORY AND PRESS FORMAT YOUR CARD THAN SHOULD BE FINE AND ABLE TO WORK ON YOUR PHONE
GOOD LUCK
Feb 06, 2009 | Nokia 6600
SanDisk Memory Card~Unrecognized file format
  1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  2. 2 Open up 'My Computer'. You should see it under the list of available drives.
  3. 3 Check its contents first to make sure that you have the right drive.
  4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
  5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Jun 30, 2008 | SanDisk 2GB Secure Digital Memory Card
Memory card is not accessible in N70 MUSIC EDITION
buy a new one .but next time when u want to format ,connect to pc suite via pc and then select memory card and delete file by file but never delete an instal program otherwise it will be corrupt again.so if u want to delete instal promgram ,go to tool / application manager and delete it from here.
Feb 21, 2008 | Nokia N70 Cellular Phone
Samsung SGH-t629 Cellular Phone Logo
181 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
