Question about Hotpoint Dryers
How to replace the Timer on a Hotpoint TDC30?
  • 4 more comments
  • pfs45 Jul 13, 2008
    I needed to see where the Few Screws Are as I have taken the Top Off and the Timer Looks really Tight? I don't want to be passed from site to site paying all the time as I have ordered the Timer! (Please Explain Where They Are)
    Model No: TDC30P
    TDC30P
    Hello Ginko;
    It States: Model No: TDC30P And Inside The Door: GRR 93693106557
    Mike
    The Wife Is Looking For The Book As This (TDC30P) Is on A
    Plate Named Model Number? And This (GRR 93693106557) Is on the Door Ginko?
    If she can't find it then I will get my Son In Law to
    have a go! You have certainly earned your Money.
    Mike
    Thanks That Did It!
    Send a link for a Feedback and you where a Great Help!!!
    Mike
  • Hotpoint Master
  • 19,396 Answers
You have to remove few screws on the panel and remove the timer wheel
Posted on Jul 13, 2008
NO DRUM ACTION ON MY TDC30 BUT DO GET HEAT
When you start the dryer does it sound as if it is running but it does not tumble? Or does it make a humming noise?
If it sounds like it's running I'd check the belt first,
Humming noise and burning smell Dan indicate a bad motor or something stuck in blower wheel.
Oct 18, 2014 | Hotpoint Dryers
Trips electric after a few seconds tdc30
your dryer has problem with the heater.to confirm the same u just switch of heater and start dryer.solution is u have to replace tha heater.
Jan 13, 2014 | Hotpoint TDC32 Electric Dryer
Tdc30 start switch doesnt stay
It is the door switch that is the problem.
Nov 07, 2012 | Dryers
My hotpoint TDC30 dryer is cutting out after 3 mins ,the drum is warm inside and wont restart till its cold inside the drum
Hi joanne balla...
Sounds like the cyclic thermostat, thermostat, fuse (differnet names for the same part)..is faulty...replace it.
You will have to remove the back from the machine, look for the air tube going to the vent of your dryer and located on it will be the thermostat/s.
To test it, remove the wires fromthe two terminals and tape them together, then try running your dryer again and if it runs and heats ok then replace the cyclic thermostat/fuse.
Go to the following webpage to see the thermostat
Please take time to rate me
http://www.espares.co.uk/parts/tumble-dryers/thermostats/hotpoint/p/1587/808
Sep 13, 2011 | Hotpoint Dryers
I have a hotpoint tumble dryer model TDC30 and it is not drying the cloths. I have looked at the heating element which was broken so I replaced it. I have buzzed out the thermostats which seem to be fine....
If you are sure that the thermostats are both ok and the element has been replaced then the only other thing it can be is either a blockage or the timer that is at fault.
Hope this helps,
Jul 21, 2010 | Dryers
Hotpoint aquarius condenser dryer TDC30
I would dry it just to be on the safe side, even though it doesn't say so. It can't hurt. The front t'stat should be under the top at or near the drum.
Feb 03, 2009 | Hotpoint Dryers
Tdc30 dryer
rthe high temp thermostat is located on the heater box,the low temp thermostat is located on the blower box ans the main fuse is the smaller round one-let me know how you do-mike
Oct 15, 2008 | Hotpoint TDC32 Electric Dryer
TDC 30 tumble dryer
To test the heating element you need to access it by taking apart the back panel, and test it for continuity using a multimeter.
There are also a couple of fuses/circuit breakers that you should test.
Entering the model number here you get the exploded view, and replacement parts.
Sep 15, 2008 | Hotpoint TDC32 Electric Dryer
Well i put it back and used it when it was still a little wet and all seemed ok! Still working fine and nothing went bang!
Apr 27, 2008 | Washing Machines
Cutting out after a few minutes
Is the water supply (for supplying cooling water to the condenser) switched on? If not, there's no real mechanism for removing heat from the machine, and it might reasonably be expected to shut itself down. Once you've got water going to the inlet hose, you might check that the solenoid valve which shuts the water off when the machine is turned off hasn't failed, and that the jet through which the water squirts into the condenser (if that's separate in this model) isn't blocked. A.
Feb 16, 2007 | Hotpoint TDC32 Electric Dryer
Dryers Logo
140 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
